11-16-2019, 09:12 AM | #1 |
Newbie Join Date: Feb 2019 Location: san francisco
| My motor is making a high pitched noise, and it's not the normal noise from an esc
I just installed a new motor and ESC in mt scx10ii, I installed a 27t brushed axial motor and hobbywing brushed crawler ESC. I am hearing a noise that sounds like the gear mesh and i can't figure it out, I tried adjusting the mesh but it just keeps the same constant loud grinding/squeaking noise. And when I put the body on it amplifies it more, any idea what the problem might be, maybe a bent motor plate? not sure Thanks for the help, I'll try to get a video up as soon as I can |
11-16-2019, 05:33 PM | #2 |
I wanna be Dave Join Date: Oct 2010 Location: Caldwell ID.
| Re: My motor is making a high pitched noise, and it's not the normal noise from an es
Check for a dry motor bushing... dry driveshaft joints... bad bearings...ect...
11-16-2019, 06:55 PM | #3 |
I'll try that, maybe a new motor plate? get back to you soon thanks for the help
11-16-2019, 07:20 PM | #4 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
Is your mesh between the pinion and spur to tight? It needs to have a bit of play. Is your pinion/spur damaged or worn out. Did you check all the teeth of the pinion/spur for a grain of sand stuck in the teeth. Why did you change the motor/esc? Did something burn up? Maybe there is an issue in the trans? Pull the motor and check for anything binding in the drivetrain Just brainstorming here |
11-16-2019, 07:33 PM | #5 |
I have checked the motor by itself, it's fine, I have checked the gears and they are fine too, and the mesh i keep adjusting it to get it perfect and just keeps doing it
11-19-2019, 06:35 PM | #6 |
Looks like you need to take a video so we can see and hear it
Tags |
scx10ii, scx10ii problems |
My motor is making a high pitched noise, and it's not the normal noise from an esc - Similar Threads | ||||
High Pitch ESC/Motor noise with throttle | Hybrid34 | Axial SCX-10 | 5 | 05-21-2015 08:37 PM |
Is this normal amount of noise | b3nchy | Axial SCX-10 | 3 | 01-12-2015 06:17 PM |
servo making high pitch noise | bubbaedc | Electronics | 4 | 08-04-2013 01:35 PM |
high pitch noise? normal? | JAKEF150FX4 | Electronics | 5 | 11-14-2005 01:38 PM |
