02-21-2020, 05:00 PM | #21 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR Quote:
The 10.2 can definitely be made into a heck of a rig though. No arguing that, just saying there is good value in the TK assuming one wants the scale transmission. | |
02-21-2020, 06:42 PM | #22 | |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Not saying the TK is a bad value, I'm saying if your plan is to upgrade it, the RBK is a better base to begin with, throwing away less money. I run brass links and chubs also for example with the lower stainless links and adjustable shock mounts all around with big bores. My RBK is now built like an ultra TK, would have wasted a ton more money if I started with the TK. I love the scale transmission, in fact it's practically required for my local comp, but I'm not convinced it's placement with the battery stuffed in the back performs better then the standard SCX10.2 setup. I'd rather toss the crap Axial shocks in favor of TRX4 or even big bores over the SSD shocks, just my preference not to throw more money away then I need too. I'll reiterate, the TK is a fantastic truck, unless you're upgrading beyond it and replacing all those expensive parts to begin with. | |
02-21-2020, 07:43 PM | #23 | |
I left this out of my last post, but my 10.2 Cherokee kit build with the ssd goodies, samix battery tray, and a lot of what you mentioned in your post, climbs better than my trail king. The TK ain’t far behind but the 10.2 has the vertical advantage. Case and point I haven’t hit this line in my TK yet, but have hit it in the 10.2 JK, a trx4 (heavily modified), and the trx10.2. Hoping to get the TK up this line some time this spring as I continue to tinker with it and try a lighter battery. | |
02-21-2020, 07:58 PM | #24 |
I definitely don't detract from the TK in any way at all. I think SSD has nailed the affordable aftermarket goodies, I'm pretty well addicted to their products and only look elsewhere when they don't have what I need. Price vs performance can't be beat. All I'm saying is that for MY needs, the TK didn't and won't really ever make sense, I WILL replace what it comes with, with SSD's own better performing parts, and what they don't offer, I get from another company. It's a fantastic truck and a great value, if you leave it alone, something I'm incapable of doing. Last edited by Xx Losungen xX; 02-21-2020 at 10:47 PM. |
02-22-2020, 09:34 AM | #25 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
I get what you are saying but in my opinion the trans on the TK is part of the performance and balance of the rig. The quality of the parts is the other half. You can upgrade the TK further but it really isn't necessary. The SBK is terrible out of the box and requires upgrades to steering immediately. Shocks are typical Axial crap, and it flops at the slightest sidehill even in good tires and foams. If money is the issue a GS02 Komodo/BOM or TRX sport is far superior. Going to upgrade my 10.2 more for balance but only reason I have it is for Axialfest at this point. Another pro for the TK is the ability to have a full and deep interior. I like to be scale. I full expect a 10.3 soon. Sent from my Moto G (5) Plus using Tapatalk |
02-22-2020, 09:55 AM | #26 | |
It's a fantastic truck and a great value, if you leave it alone, something I'm incapable of doing. | |
02-22-2020, 12:11 PM | #27 |
Newbie Join Date: Apr 2017 Location: Everett
I was able to get the RBK driving under it's own power yesterday. Shimming the drivelines .30mm helped the R&P's quite a bit. Other things that were changed right from the start was a metal servo horn and I flipped the 3 upper link ends at the skid plate to avoid interfering/binding with the lower links. So far, I'm happy the way it operates and am looking forward to getting a body installed. |
02-25-2020, 02:04 AM | #28 |
Newbie Join Date: Jan 2020 Location: lugagnano val d arda
Truly a beautiful machine, with excellent materials!
03-01-2020, 10:18 AM | #29 | |
Progress Update: I'm still continuing to fine tune the SCX10 ii and loving it. The Proline '85 Toyota SR5 Hilux body is now being fitted and painted. The body was listed as a 12.3" wheelbase. Using the recommended body mount hole locations and lining up the front axle to the fender arches, shortening the WB to 12" made it spot on. The tires on it right now are listed as 4.25" and those will be changed out for 4.19's to be compliant with Class 1. So far, I'm really happy with it. 12" wheelbase, 4.25" tires, 1.9 wheels Testing at Pacific RC Arts. Pictured with my son's ECX Barrage Sumo Samurai running RC4WD 1.55 Mud Thrashers. | |
03-09-2020, 12:55 PM | #30 | |
My progress: The Proline Toyota '85 SR5 Hilux body was painted and turned out ok. I'm still learning the paint process and would like to buy another body and try it again in drier, less humid weather. For wheels and tires, I bought the wheels off of Amazon. They were cheap ($39.99) but are round, beadlocks and effective. I especially like that they are period correct of wheels that were available in the late '80's and early '90's. The tires are Proline BFG KM3 Class 1 4.19" in the K8 compound. With the weight of the metal wheels over plastic, added hardware and new tires, the net gain was 7.45 oz of unsprung weight to the truck. The truck now weighs 5.25 pounds and acts very predictable as I am learning to drive it. | |
03-27-2020, 11:25 AM | #31 |
| Re: Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR |
Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR - Similar Threads | ||||
Almost finished with my scx10 raw builders kit | Alphaauto | Axial SCX-10 | 3 | 10-10-2019 01:49 AM |
Possible to build a 9.5-10" wheelbase SCX10 II out of the Raw Builders Kit? | wwaveform | Axial SCX10 II | 5 | 03-29-2019 05:01 PM |
Cherokee kit or Raw Builders Kit? Can’t decide! | twentyniner | Axial SCX10 II | 12 | 12-02-2018 09:14 AM |
SCX10 II raw builders kit-questions | Spence | Axial SCX10 II | 2 | 11-11-2018 07:34 AM |
