04-01-2020, 09:02 AM | #1 |
Newbie Join Date: Mar 2020 Location: Germany
| Help me compare SCX10 iii kit vs TRX-4 sport kit
Suppose that no mini-servos are installed in SCX10 iii, in order to compare a basic performance between [SCX10 iii kit] and [TRX-4 sport kit]. Furthermore, let us consider AXE550 motor and esc combo and C900W servo for both of them. Can you compare their performances in crawling? I'm just about to buy the one that beats the other. |
04-01-2020, 11:46 AM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: San Francisco
| Re: Help me compare SCX10 iii kit vs TRX-4 sport kit
Apples to apples, the only things that really seem to be a deciding factor for the SCX are the frame rail adjustability & battery size/location options. Wheelbases are +/-1mm, portals on both, solid parts support from the aftermarket, etc. While I don't have any hands-on with the TRX, when I compared the torsional stiffness of the new SCX chassis to my VS4-10 chassis, they were damn near identical in terms of stiffness... and that VS4 is stout!
04-02-2020, 01:12 AM | #3 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
For my preference, I like the SCX10 III axles as thjey are more slimmer. The TRX axle are bulky as hell
04-02-2020, 04:10 AM | #4 |
| Re: Help me compare SCX10 iii kit vs TRX-4 sport kit |
04-02-2020, 04:14 AM | #5 | |
| Re: Help me compare SCX10 iii kit vs TRX-4 sport kit Quote:
Wouldn't the frame rail adjustability make the frame relatively weaker than a non-adjustable frame? | |
04-02-2020, 07:42 AM | #6 | |
Quarry Creeper Join Date: Mar 2014 Location: Masshole
TRX has the same but you can only lower the larger center battery tray with an aftermarket part and the shorty tray is high in the chassis between the front shock towers. The frame rail stock setup is 12.3" WB. From here you can adjust it to a shorter WB and not a longer WB unless you do something custom currently. So you build it stock at 12.3" WB or shorten it. The frame rails would not be weaker if you were to shorten them. | |
04-02-2020, 08:08 AM | #7 |
| Re: Help me compare SCX10 iii kit vs TRX-4 sport kit No, where the 2 pieces of the frame meet is a very low stress area plus there is a large overlap which essentially doubles the thickness and strength through that area. It is much like the Ascender chassis which has an incredibly low rate of failure (I have never seen one of those bend).
04-02-2020, 08:52 AM | #8 |
| Re: Help me compare SCX10 iii kit vs TRX-4 sport kit With thinner axle housings you get more clearance/less things dragging on the rocks. That's almost a nonissue with portal axles though. TRX-4 axle housings are beefy and they also have the locking diffs so that's why they are a little bigger than those of the SCX10 III. I wouldn't call them bulky as hell though. I'd argue the battery placement on the TRX-4 is better since it's more centrally located and you can get it to be lower. I have a small battery on the driver's side floorboard and it throws off the weight balance of a truck a lot. The other option is to put it way in the back, but you don't want your weight out back IMO. Last edited by JatoTheRipper; 04-02-2020 at 02:19 PM. |
04-02-2020, 09:58 AM | #9 |
04-02-2020, 03:55 PM | #10 | |||
Add some weights would be necessary for keeping the weight balance with a shorty batter pack on the side floorboard. That's perfect! I now feel like I want to order the SCX10 iii kit ASAP. Please stop me if you think it's good to wait a little bit. | |||
Help me compare SCX10 iii kit vs TRX-4 sport kit - Similar Threads | ||||
TRX-4 Sport Kit VS Capra | Nez02 | Newbie General | 13 | 04-15-2020 10:17 PM |
TRX4 Sport kit or TRX 4 Crawler kit Question | redpeppers | Newbie General | 13 | 09-15-2019 06:00 PM |
TRX 4 Sport Kit vs Axial SCX10 II? | mattbhm | Traxxas TRX-4 | 24 | 03-20-2019 01:10 PM |
TRX-4 Sport Assembly Kit! | nedmo | General Scale Talk | 22 | 03-02-2019 06:52 AM |
TRX-4 sport/Bronco kit | BrianP | Traxxas TRX-4 | 19 | 10-27-2018 07:31 AM |
