01-30-2022, 12:45 PM | #1 |
Newbie Join Date: Jan 2022 Location: Rydal
| Back wheels not turning at the same speed as front
I got my SCX10 iii the Sunday before Thanksgiving. I have about 1.5 to 2 hours run time on the Jeep. Original dig servo was dead from factory and Horizon Hobby sent me a replacement. The problem now is that both back wheels will not turn when under any type of load from an incline. I have disconnected the dig servo and have the same issue. I am at a loss for what is causing this and any ideas would be greatly appreciated.
01-30-2022, 01:05 PM | #2 |
RCC Addict Join Date: Mar 2019 Location: Hemet
| Re: Back wheels not turning at the same speed as front
When you disconnected the dig servo did you move the lever all the way in towards the front of the truck while spinning the rear wheels to make sure it’s engaged? There is a neutral spot in the cog for the gear that allows the rear wheels to freewheel. I had mine setup this way using an upgraded remote. So if the settings are not correct on that servo, that could be the issue. Did you plug in the servo and make sure it was at the correct position before hooking up the servo arm? Sent from my iPhone using Tapatalk |
01-30-2022, 01:50 PM | #3 |
That might have been the issue. I will have to wait until later to try it under a load. I will post back after I have had a chance to test while running.
01-31-2022, 07:53 PM | #4 |
That fixed my issue. Thank you
01-31-2022, 10:20 PM | #5 |
| Re: Back wheels not turning at the same speed as front |
Back wheels not turning at the same speed as front - Similar Threads | ||||
Turning 2 speed trans into single speed | Betts818 | General Crawlers | 2 | 06-20-2016 12:52 PM |
Front wheels crawl over but the back wheels spin! | burgerboy78 | Newbie General | 2 | 02-14-2014 10:40 AM |
Widen Stock Front Wheels for Better Turning? | Reason Being | Losi Micro-Rock Crawler | 2 | 01-23-2012 10:07 PM |
back wheels are turning before front? | tombs | Redcat Crawlers | 18 | 04-20-2010 10:05 PM |
Front wheels spin more than back | Eagle-Mark | Tamiya Clod Buster | 11 | 05-22-2005 11:33 PM |
