03-18-2022, 06:49 PM | #1 |
Newbie Join Date: Mar 2022 Location: Anderson
| High or low gear
Putting my kit together and was reading through the post at the top about the things to keep on mind when building it. I'm not doing the 2 speed. So I'm guessing lock it in first
03-18-2022, 10:20 PM | #2 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: High or low gear
Yes I would lock it in first Sent from my iPhone using Tapatalk |
03-19-2022, 07:00 AM | #3 |
i have a few rigs that i can switch gears on manually but they spend most of there time in first gear it is nice to be able to switch gears though i would try to figure out a way to manually change the gears |
03-19-2022, 07:49 PM | #4 |
Pebble Pounder Join Date: Mar 2015 Location: East coast Canada
Im running a Hobbywing Fusion 1800kv in my 10.3, i just recently swapped the dig servo to shifting duties ( this rig only sees trailing use now mostly ) i find myself using second gear more than first. If you have access to a 3d printer, there a file on thingiverse that will let you lock the shift arm in either first or second gear, but let you manually change it. Id go that route There isint a whole lot of difference between first and second gears |
High or low gear - Similar Threads | ||||
What's wrong with my TRX-4? High/low gear shifting problem. | ykw_n | Traxxas TRX-4 | 9 | 09-22-2021 10:20 AM |
Low or high gear? | Fishcharger | Axial SCX10 III | 4 | 04-02-2020 08:18 AM |
Low or high gear? | Thickone | Vaterra Ascender | 1 | 08-04-2017 08:46 AM |
AX10 shift kit or shifting from Low gear to High gear? | legobrains | Axial AX-10 Scorpion | 19 | 10-27-2007 12:24 AM |
High/Low Gear ? | Fishmaxx | Traxxas Crawlers | 1 | 02-25-2004 08:37 AM |
