![]() | #101 |
Quarry Creeper ![]() Join Date: Jul 2007 Location: Powder Town
Been having too much fun with it to update this thread... lol ![]() ![]() New 6.5" Crawler Innovations Ripsaws are mounted up! Vanquish Disk Brake setup OTW. ![]() |
![]() | #102 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
Sick!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
![]() | #103 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Hey rojo, In the battery tray pic, looks like you just used a flat piece of delrin, correct? Did you run the 2 outer screws through the straps? I'm wanting to do a different battery tray up front, rather than cutting down the stock tray and going that way. Thanks! Sent from my iPhone using Forum Runner |
![]() | #104 | |
| ![]() Quote:
![]() | #105 |
Thanks rojo!!! I'm guessing you used a flat washer and a nut to secure the strap, as well? Sent from my iPhone using Forum Runner Last edited by 2-shot; 07-04-2012 at 09:16 AM. |
![]() | #106 |
Vanquish Brakes are on! ![]() ![]() ![]() ![]() ![]() Also installed some RPM shock protectors to keep the flying debris off my shock shafts... ![]() ![]() ![]() ![]() Almost Done! Just a few more things to do... ![]() ![]() |
![]() | #107 |
More work done today! Front sway bars installed. I had to use a mix of parts from the front and rear axial kits to make it work. I used the links and softest sway bar from the "front" kit and used the shorter arms from the "rear" kit. I also had to use an offset rod end to clear the shock on the bottom mount. I had to mix and match them because of my front shocks being relocated so far forward, along with the larger diameter shocks I am using. Either way, I think it turned out great, and will definitely help control the body roll a lot better at speed. I'm planning on leaving the rear without as I didn't want to kill all my travel. Link Setup: ![]() Driver side: ![]() Passenger Side: ![]() Straight on: ![]() |
![]() | #108 |
Approaching the finish line on this build... Last major detail, the rear deck cover: Made out of styrene and foam with the TTH logo inset into the cover. (Been watching way too many custom car shows lately...lol) Also put on a trail rack complete with cooler and tow strap. A few pics with the top off: ![]() ![]() Top on and loaded up: ![]() ![]() |
![]() | #109 |
Got a chance to take out the Wraith this afternoon. I'm still working on my 4WS skills, but wow is this thing capable. The 6.5" ripsaws are insane. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #110 |
Pebble Pounder Join Date: Sep 2010 Location: West Linn
So awesome, the larger ripsaws are what everyone needs. Really like the looks of them! Nice work
![]() | #111 |
I wanna be Dave ![]() Join Date: Dec 2009 Location: Outside DC
Holy shizzle! 6.5 ripsaws? CI did this? This is the first I've seen of this! They actually make the axles look scale! RC4WD...Please follow!!! Let's shift the whole hobby to 1/8th scale!
![]() | #112 | ||
| ![]() Quote:
Props goes to Crawler Innovations for making this set. ![]() | ||
![]() | #113 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
Are those slash proline shocks? If so the front or rear ones? Build looks good I can't wait to get mine going!
![]() | #114 | |
| ![]() Quote:
![]() On a side note, I have a few more special updates coming on this build... I blew out a axial universal which also buggered a felenfest locker... bigger and better parts en-route! ![]() | |
![]() | #115 |
Time to update with a few changes made over the last part of this year... Still having a blast with this truck! First off, I swapped to GCM Steel Metal-Head AR-60 axles. These were the first ones he made (and the only ones in steel that I know of). It took a little fitting between the Vanquish C and Panhard mount, but they went together rather smoothly for being a custom-ordered axle. I also chose a black oxide coating to protect the steel a bit from the elements. ![]() (Internally I switched to Vanquish Lockers and VVD's. I'm still currently running under-drive gears front and rear) Also, just to note, The GCM housings give a gain of about 1/8" of ground clearance under the diff over a stock style housing. ![]() ![]() ![]() ![]() ![]() Next up was to install a little lighting for the after-hour runs. I chose the MadDog Exo light bar (and adapted it to the Wraith) along with some MadDog Rock Lights. Wow, these things are bright! ![]() ![]() ![]() ![]() ![]() Last came a wheel swap to some LockedUp RC Rock Cutters. They required the removal of the Vanquish brake kit, but are absolutely worth it. ![]() ![]() ![]() Its been raining a lot around the house, but I will try to get some out-side shots posted up soon! |
![]() | #116 |
I like the upgrades and love the axles. Everything looks perfect. Thanks for the update. ![]() |
![]() | #117 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
awesome rig man,love thet u can make changes and upgrades every week
![]() | #118 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
ur rig is sick nice work
