10-20-2011, 11:44 AM | #21 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Keep an eye in the for sale section on here. I just got some Vanquish DH Pro Comps for mine for $60. I love them and they look good plus they are adjustable offset. I run 460 hubs on mine which seems to be real close to stock. It is better to spend a little extra now than to have to buy something now and then buy again later. Or at least that is the way I look at it. If you plan on going to Vanquish knuckles some of the wheels like the XR10 wheels won't work without being narrowed or putting wideners on it. |
10-20-2011, 12:08 PM | #22 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
if all else fails get a set of axial 2.2 rocksters or 8-holes! |
10-20-2011, 12:21 PM | #23 |
11-01-2011, 03:48 PM | #24 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
Got the wheels, got the Wraith, and got the truck all together except the outer body panels. Wheels fit good. Tires just barely rub the lower links at full lock. They also rub the shocks but I have the stage3 lowering/droop setup on it and the shocks are in the rear holes so I'm going to move them to the forward holes and see if that helps. I have disassemble the fronts anyway because the tires refuse the stay centered with the big weights the wheels came with so I'm going to do a track width measurement once I have the front wheels apart again in comparison with the stock wheels. Must say I really like the truck. I haven't been able to drive it much though because I bought a AE-2 out of the RPP scrapyard when I bought the truck and I didn't realize that it came pre-setup for lipo cut-off and I still use the old nimh batteries so it only runs a few minutes before it starts powering down. So, I got a castle link, a axial 2.4ghz controller/receiver from the scrap yard, and a hot racing steering setup. That should all be here Friday. My only bitch is it's a pain to work on. I got it all together, then first time I went to drive it the motor just spun, I forgot to tighten up the grub screw on the pinion gear all the way after I set the mesh. So I had to drop the skid plate and pull the whole trans to get the cover off and reset the mesh. |
