01-14-2012, 07:34 AM | #1 |
Newbie Join Date: Jan 2012 Location: texas
| CMS help anything other then look?
I have seen alot on scx10s but not many on wraiths. I just got my wraith kit in the mail yesterday and looking at parts to add. I like the look of the chassis mounted servo but didn't know if it was really better performance wise just left on the axle? So if I did buy one, would the one with the panhard bar be better to keep from shifting the a axle while steering. On those kits you have to remove one of the upper links to allow proper suspension cycling. Bottom line is it just for looks or will it help do anything? |
01-14-2012, 07:57 AM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
| Re: CMS help anything other then look?
It's designed for the scaler appearance, so more life like.
01-14-2012, 02:37 PM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Not true, while it is life like the performance can be better in some situations plus it's just sweet! It also beefs up the front bumper because of the servo mount and gets the servo out of the way.
01-14-2012, 03:37 PM | #4 |
Rock Stacker Join Date: Nov 2011 Location: united states
The four links locate the front end. Pan hard bar will do nothing for the axle moving side to side. Y buddy bought all that and after looking at it the panhard does nothing. But I will say it looks like the real deal.
01-14-2012, 07:19 PM | #5 |
Rock Crawler Join Date: May 2007 Location: Prescott
| Re: CMS help anything other then look? Wow. Misinformed you are. Next time state crap like that and put that it is your opinion cause it is in no way the facts. |
01-14-2012, 07:32 PM | #6 |
| Re: CMS help anything other then look? This is all wrong man, have you ever even used a rig with cms? Because without it you may have bumpsteer problems plus most people get rid of one of the uper links so that combined with the panhard essentially 4 links it, just not the same lol but yea, it is necesary most of the time. But hey if its not needed then take it off of your 1:1 and then you will see why it's there |
01-14-2012, 10:51 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: Fairbanks, AK
I'm in for just looks. I build 1:1s and will tell you that with the longer travel and better articulation (scale or full size), panhard set-ups are more difficult to make work well. That is because the more the suspension cycles, the more the panhard rod changes in geometry, thus moving the axle side to side more. The panhard must match the drag link length and angle, or you get Bump Steer. If you look at 1:1 long travel rigs, they all (well, mostly) have axle mounted steering. That is partly due to saving space under the motor, around frame, and above the axle. Mostly, its easier to engineer suspension that actually works without having to worry about steering/panhard geometry. |
01-15-2012, 02:08 AM | #8 | |
I wanna be Dave Join Date: May 2006 Location: akron
| Re: CMS help anything other then look? Quote:
01-15-2012, 06:47 AM | #9 |
Thanks for the replys.
01-15-2012, 10:04 AM | #10 |
Wow you dudes are harsh. All I was saying is I took my buddy's pan hard bar off the axle it self never really went side to side. Wasn't trying to bash the dude. Damn
01-15-2012, 12:20 PM | #11 | |
RCC Addict Join Date: Nov 2004 Location: union
But like me, I need a 3 link to clear driveshafts, so it could be used for other things as well. All people will have different needs and applications. | |
01-15-2012, 02:19 PM | #12 |
Yeah .my buds wraith is still a four link . The guy who started this post said thats what he wanted to know more about it on one. Figure i would say what I saw about it. But instead I got ppl jumping down my throat . It all depends on what you want and the look you want. I lime the scale look .
01-15-2012, 02:30 PM | #13 | |
01-15-2012, 04:11 PM | #14 |
| Re: CMS help anything other then look? Thats why I told him to take it off
01-15-2012, 04:28 PM | #15 |
01-15-2012, 05:52 PM | #16 |
Rock Crawler Join Date: May 2009 Location: branchville
here is what i found on the rpp web site about the vp cms * You can run the chassis mounted servo with out the pan hard kit. if you run this way you would keep your links stock with all 4 links still attached. * If you run CMS and the panhard, it requres you remove one of the two upper links to make it a 3 link setup. If you run 4 links and the Panhard there will be binding in the suspension. *A new drag link with traxxas ball ends or VP drag link is required to replace the stock drag link, The stock link ball ends do not rotate quite far enough.* |
01-15-2012, 06:02 PM | #17 |
| Re: CMS help anything other then look? |
01-15-2012, 06:25 PM | #18 |
It's a trial and error process if you are doing your own kit but thanks to vp and rc4wd etc. they did all that for us!
01-15-2012, 06:30 PM | #19 | |
testing first try at chassis mounted servo - YouTube | |
01-15-2012, 06:33 PM | #20 |
CMS help anything other then look? - Similar Threads | ||||
level 3 rc cms? | muddinscx | Axial SCX-10 | 30 | 01-31-2015 05:47 AM |
Rear CMS | neoakaj | Axial Wraith | 1 | 12-17-2011 09:45 AM |
CMS Question | alexchen86 | Electronics | 6 | 07-15-2011 03:36 PM |
CMS advantages? | Big Daddy | Axial SCX-10 | 8 | 07-14-2011 11:21 PM |
Cms help! | xtian | Axial SCX-10 | 2 | 09-26-2010 10:10 AM |
