01-19-2012, 04:58 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)?
I'll be using HH BR-XL, the Futaba 4PL, running 3S lipo. I need a wiring diagram of how to attach 2 CC 10A BECs, so that I can have 4 wheel steering, using 2 Hitec HS-7955TG servos. Should I bypass the receiver, and solder directly to the servos? What are the advantages and disadvantages in doing so? What voltage should I set the BECs? Which are the wires I should disconnect from the plug? I'd greatly appreciate the help. TIA.
01-19-2012, 05:09 PM | #2 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? |
01-19-2012, 05:52 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
I made this up real quick. oh one other thing. If this is your first time working with the HH BRXL's you need to know a secret I found out the hard way. YOU MUST program them individually. In other words you can not solder the power input wires together from the battery voltage before you program them. It may be in your best interest to have plugs on at least one of them so you could unplug it from the lipo to program. Hope this helps. Last edited by Illeagle; 01-19-2012 at 06:10 PM. |
01-20-2012, 05:58 PM | #4 | |
I will be only using 1 HH BR-XL esc. Will the wiring diagram you posted still work, by just removing the other HH BR-XL? Also, do I need to disconnect the red wire from the esc to the throttle channel on my receiver? Or, leave all the wires plugged in from the HH BR-XL going to the RX? Quote:
01-20-2012, 06:28 PM | #5 |
You can use one esc but both motors will always be spinning so you have no front/rear control for digs. You can get a punk dig switch which will turn off one motor at a time with just one Brxl and use your 3rd channel to control it. In my wiring diagram you leave the red wire connected from the Brxl to the rx. You would only need to remove it if you had a bec powering the rx instead of your esc.
01-20-2012, 08:37 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
First guys the OP is asking about wireing it up for 4WS not running dual motors/esc's. The BR-XL has a very good internal bec so I think 2 external ones will be a bit overkill. Run the front servo useing the castle bec and the rear useing the internal bec from the BR-XL. Rear servo plugs into slot 3 of the receiver and the signal wire from the front servo into slot 1. drop the signal lead comming from the bec and wire the other two into the coresponding two comming from the front servo. Then watch Harley's video on setting up the 4PL for 4WS. |
01-20-2012, 09:21 PM | #7 |
My bad... I assumed you were building a super for some reason. Here is another option as described above. Last edited by Illeagle; 01-20-2012 at 09:46 PM. |
01-20-2012, 09:32 PM | #8 |
Quarry Creeper Join Date: Jun 2009 Location: HOBBY HQ
there is no need for 2 bec period i have two high voltage savox servos running 4ws with a fxr on 3s and its just fine also if your servo asks for 6v set your bec at 6.1 you loss .1v thru wiring
01-21-2012, 04:50 AM | #9 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
OMG this so helps me also, your running the EXACT electroncs as me. lol
01-21-2012, 08:41 AM | #10 |
...So, do I follow exactly as pictured in the wiring diagram below? Or, do I need to disconnect the red wire from the esc to the throttle channel on my receiver? Or, leave all the wires plugged in from the HH BR-XL going to the RX? Lastly, do I need to disconnect any wires from the rear servo going to the RX? |
01-21-2012, 10:10 AM | #11 | |
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? Quote:
01-22-2012, 09:45 PM | #12 |
..what if I use a Tekin RS Pro esc instead of the HH BR-XL, would it matter? The Tekin RS Pro's internal BEC is 6.0V/3.0A. Can I run the rear steering Hitec HS-7955TG servo directly to the receiver, using the Tekin RS Pro's internal BEC?..
01-23-2012, 12:25 AM | #13 |
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? I dont know if Tekin's internal bec would be up to the task. Most esc's internal bec's are no where near putting out what there advertised too. The BR-XL's internal bec is one of the best there is out there.
01-23-2012, 12:35 PM | #14 |
Rock Crawler Join Date: Jul 2009 Location: greeley
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? I would argue that an amp is an amp. But some BEC's rate there BEC amperage rating at the 7.4 volt not the 11.1. Since Holmes is osalated it doesnt matter if run 7.4 or 23 volts you get 5 amps. The thing I haveta ask is why would you want a 2 BEC's with a BRXL. I run a front servo and lights on a BRXL. Seems to work pretty good. I would use 1 for my front and power lights and rear off speed controll to save $30
01-23-2012, 01:58 PM | #15 |
Rock Stacker Join Date: Nov 2011 Location: St. Petersburg
Why all the fuss, just run a cc bec pro, and be done.. it'll prob be cheaper than 2 10amp because too.
01-23-2012, 05:19 PM | #16 |
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? I made the first illustration up for wiring a SUPER class crawler and not just a scaler. Most guys run two 7980/7990 servos right now. Just one of those servos can draw WELL over 5 amps and closer to the 10 that a Castle Bec puts out. For those rigs having two bec's with the full 10amps to EACH servo is standard. |
01-26-2012, 12:28 PM | #17 |
Pebble Pounder Join Date: Mar 2010 Location: Minden, Nevada
| Re: how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? I'm planning on running the same electronics as the OP as well. But from what others are saying you don't need two, and from what i am gathering the CC BEC PRO would be over kill and a waste of money. Use one CC BEC and use the BEC internal to the BRXL should be fine, am i correct? I have been searching to find this out my self. I need to still buy the radio and i was going to get the BEC at the same time. But if i can save my self a couple of bucks and not piss of the wife at the same time, its a HUGE plus. |
01-26-2012, 01:05 PM | #18 |
Pebble Pounder Join Date: Dec 2009 Location: Magalia, CA
I am running these which are pretty nice as far as hooking up to your servos and not having to disconnect the power wire like it says on the directions... CreationFab - Plugs Other Receiver Bypass Adapter |
01-28-2012, 08:47 PM | #19 | |
BTW, the merchant paypal account is chris@creationfab.com.....Is he the same as Chris_The_Battery_Man here in this forum? Both of their websites look very similar, so I was wondering. Does anybody know if both Chrises are the same guy? | |
01-28-2012, 08:52 PM | #20 | |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? - Similar Threads | ||||
Definitive wiring diagrams for BECs Rx Servos Motors etc. | O.C.D. | Electronics | 214 | 09-14-2018 09:30 PM |
solder wire to motor? | ykcor | Newbie General | 12 | 04-10-2008 10:20 AM |
Venom Wire Solder - Which is +? | SgtDoogie | Electronics | 4 | 03-26-2008 10:48 AM |
brazing wire/solder | Wicked_Jester | Tools, and Procedures | 5 | 06-17-2007 08:12 PM |
