03-09-2012, 11:12 AM | #1 |
Newbie Join Date: Feb 2012 Location: Sterling
| Waterproofing servo
What is the best way to waterproof a servo?
03-09-2012, 11:27 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
| Re: Waterproofing servo
Check the electronics forum, lots of great info and ideas there
03-09-2012, 12:25 PM | #3 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
Put dielectric grease around the output shaft on the inside of the case. Don't put too much because it will gum up your gears. Go to Home Depot, get some Plasti Dip, it will be in the electrical or paint department. Dip the servos, before it gets full cured push the servo horn on.
03-09-2012, 01:24 PM | #4 |
Rock Stacker Join Date: Dec 2011 Location: calverton
liquid tape. All i've done is put it around every crack and seal or any area where water can get in minus the output shaft, and i've never had problems. edit: and to prove this worked, i sunk my crawler king in a frozen lake, and everything still worked perfectly hours later and still does to this day. it was submerged on a weekly basis |
03-09-2012, 02:23 PM | #5 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
You can use a balloon or rtv sealant. I prefer the rtv sealant becasue its black and maintains the OE look. I've done a few of them and it works like a charm. Plus it doesnt look like a big glob on your servo like the plasti-dip does.
03-09-2012, 02:34 PM | #6 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
I use black colored balloons. However, balloons deteriorate over time, so I just replace them when needed.
03-09-2012, 02:43 PM | #7 |
Rock Stacker Join Date: Jan 2012 Location: Birmingham
Ultimate RC has a video how to on you tube that will give you a good idea of how to do it. It's step by step so it makes it really simple. Check it out and I hope this helps.
03-09-2012, 07:59 PM | #8 |
Rock Stacker Join Date: Nov 2011 Location: Marysville
Get some liquid electrical tape and seal up all of the cracks minus the servo horn. Then put some grease ( preferably marine grease) around the servo horn.
Waterproofing servo - Similar Threads | ||||
JR Servo Extensions & Waterproofing? | ravencr | Electronics | 1 | 09-13-2012 09:47 AM |
waterproofing esc and servo | CIELO | Newbie General | 7 | 08-25-2009 02:12 PM |
Servo waterproofing | zumzum5150 | Electronics | 0 | 04-09-2008 05:57 PM |
waterproofing a servo for $10 | smm_cbf | Electronics | 7 | 12-31-2007 09:27 PM |
