03-24-2012, 09:29 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: chico
| 2.2 comp wraith a.k.a. CRAWLBETTA updates with pics
So, A long time ago I realized I just don't have the capacity to leave things alone. I like the wraith its a fun basher. But I like crawling better than bashing and have missed my ax10 since I traded for a welder. The wraith axles are really cool looking but for my style of driving, and the terrain around here they're just too wide. I'm sure its not the only way to do it but this is what I came up with. This is what it looked like yesterday. First I disassembled the axle. I then cut 1" out of one housing and 1 1/8" out of the other using my pittsburgh pipe cutter. I used this tool because it was an easy way to assure the cut would be square to housing. I did have to smooth out the flat spot where the factory truss bolts down to use the pipe cutter.I also wanted a slightly narrower rear hence the 1/8" difference. Anyway heres some pics hope you guys like it. If not thenlol Here's A couple pics of the stainless steel tube i bought for 6 bucks at a hardware store Then I clamped visegrips to the end to make it stand up' obviously a vice would be better but this worked well enough. I used my small butane torch to heat up the end of the tube till it was red hot. I pushed the housing down on to the red hot tube as far as it would go keeping it as straight as i could and pulled it off quickly before it bonded permanently. I did this because excess plastic oozed out and needed removed, I did this twice. the third time it went in far enough. After that I cut the tube so it was as long as possible without interfering with the screws that hold the link bracket on the housing. Oh and I beveled both ends of the stainless with a grinder before heating. Then you heat it up again an repeat. Once its on the stainless and cools for a few seconds I could not remove it. You don't need any adhesive. It will slide apart a little if you don't hold it together for like 5 seconds. After that I heated up a peeling knife and welded the seam and sanded it smooth. I haven't tested for brittleness but I don't think it will be a problem this stuff seems to want to melt not burn. Well I hope you like it. Last edited by cooterwrenchen; 04-21-2012 at 12:10 PM. Reason: changed title a little |
03-24-2012, 10:30 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
| Re: How I narrowed my wraith axles
Very interesting, Want more pics! installed and wonder how they will hold up as well... Love the 1 piece design with the Wraith axles but the scale of the sxc10... best of both worlds!!!! NICE |
03-24-2012, 11:02 PM | #3 |
Ya that's why I did it for sure. I'll definitely keep you posted on the strength. I'm going to start a build thread using these axles but it might be awhile, i'm still waiting on some parts.
03-24-2012, 11:18 PM | #4 |
Right on man keep it up!
03-24-2012, 11:48 PM | #5 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
What are you doing for axles?
03-25-2012, 01:20 AM | #6 |
Until my lhs gets the wraith universals I'm going to have to cut, sleeve, and weld the stock axles I guess.
03-27-2012, 12:39 PM | #7 |
| Re: How I narrowed my wraith axles/the 2.2 comp wraith a.k.a. ROCKSTORM
Hello again. I've made a little progress on my build so I thought I would start the build portion of this thread. I'm using the the stock skid for this one. Here's a few spy pics. The first one is of the axles mocked up with the lower links in the 12.5" wheel base jig I'm using Acetel for my lowers as you can see. I'm not sure if I should dye them or leave them white. I've also offset the skid towards the front. Here you can see the the plate steel i'll be welding the tube to. |
03-27-2012, 01:48 PM | #8 |
| Re: How I narrowed my wraith axles/the 2.2 comp wraith a.k.a. CRAWLBETTA
It's hard to see anything with those small pictures.
03-27-2012, 02:08 PM | #9 |
| Re: How I narrowed my wraith axles/the 2.2 comp wraith a.k.a. CRAWLBETTA |
03-27-2012, 03:04 PM | #10 |
Sorry about that there from my phone ill enlarge them on Photobucket when I get home
03-29-2012, 05:05 PM | #11 |
Here ya go. Made some sliders and tried to bend the main tube for the chassis... but that was a disaster.So I made a bender to make things easier, I broke the dial down to 11.25*. that should make it easy to duplicate bends. sliders overall SBC piece de resistance Hope you guys like it. because I sure do. |
03-29-2012, 06:16 PM | #12 |
Rock Stacker Join Date: Feb 2012 Location: Elmo AFB
| Re: the 2.2 comp wraith a.k.a. CRAWLBETTA with properly sized pics now
Nice Bender man! I am def keeping a eye on this build, hell of a good start!
03-29-2012, 06:20 PM | #13 |
Thanks man. I just hope it keeps moving along as quickly as it has.
03-30-2012, 10:02 PM | #14 |
Newbie Join Date: Oct 2011 Location: United States
Don't think you'll be calling that a wraith for much longer. Should be petty cool.
04-21-2012, 12:00 PM | #15 |
| Re: the 2.2 comp wraith a.k.a. CRAWLBETTA updates
I finally have some progress to show you guys. new parts list as follows RRP gears for my wraith transmision CC BEC CC sidewinder SV2 HH expert torquemaster 35t eco power 30c 3s 2200mah battery VP chubs strc nuckles for now savox digital SA-1283sg i also got some tube work done. The back isn't done, thats just as far as i made it last night. That's about 3 1/8" belly. I think i'm going to lower it a half inch This is my first go at a tube chassis so be kind. The guys that do these often have some major talent. I throw away 1 out of 5 bends. Ill have more progress to show you guys tonight i hope |
04-22-2012, 04:01 PM | #16 |
| Re: 2.2 comp wraith a.k.a. CRAWLBETTA updates with pics
Started on the front end today, got far enough to mock up the shocks and see how she flexed. It seems i will be limiting them. Here's some pics. Let me know what you guys think, and any suggestions would be welcome because i've never built a tuber before. Here it sits at like 3 1/8". Should i lower it? I think this is more than enough flex Thanks for any imput |
04-22-2012, 07:03 PM | #17 |
| help
If you were making your own tie rod would you want a little toe in, or toe out?
04-23-2012, 05:55 AM | #18 |
Quarry Creeper Join Date: Nov 2011 Location: dark corner
a little toe out would be more stable for sidehills but more toe in would help your turning radius. i guess its all in what your looking for out of it
04-23-2012, 11:18 AM | #19 |
hmm. I was thinking toe out would pull me off of side hills. I got it pretty much even this morning |
2.2 comp wraith a.k.a. CRAWLBETTA updates with pics - Similar Threads | ||||
Narrowed Wraith axles... the easy way | Chris_The_Battery_Man | General Crawlers | 19 | 03-10-2013 03:45 AM |
Narrowed Wraith Axle interest? | Chris_The_Battery_Man | General Crawlers | 33 | 01-23-2013 04:23 PM |
Narrowed Wraith wheels for XR | mindless | Tires and Wheels | 13 | 02-11-2012 09:20 AM |
narrowed wraith? | heinie_21 | Axial Wraith | 15 | 10-19-2011 10:21 PM |
Narrowed WK Axles | MetalMan | HPI Wheely King | 17 | 02-07-2008 01:08 AM |
