04-01-2012, 10:38 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Simi Valley
| The Rock Bus
well this is wraith number 3 for me...first one i hated after 10 minutes with it so i sold it,second one i got in a trade and it had just about all of the vanquish catalog tossed at it and i had it 7 hours and hadnt even driven it and it was traded away for something i wanted and now we are here at lucky number 3. i actually want to keep and upgrade this one and make it a nice well balanced rock rig/tow rig for my fleet of scx10 scalers. the color on this one was a challange of close my eyes and turn around 3 times and then grab the first can i felt on the paint rack at the hobby shop and this is what it was,so i embraced the color and chose 1 of 2 themes the color would work with...a taxi or a school bus....here is the rock bus. ive done the hinged hood mod and the battery under hood relocation and relocated the esc to the top of the transmission...are there any susggestions right off the bat for this bone stock rig that should be addressed before hooking a battery up and finally driving it? Last edited by DroopysGarage; 04-02-2012 at 05:30 PM. |
04-02-2012, 09:21 AM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: The Rock Bus
Just make sure you check that everything (nuts, screws) are tight. Then run it like you stole it and then check it again. Enjoy.
04-07-2012, 09:51 PM | #3 |
Newbie Join Date: Dec 2011 Location: plano
| Re: The Rock Bus
yea my axle nuts were backed all the way out after one run
04-08-2012, 01:14 AM | #4 |
Rock Stacker Join Date: May 2010 Location: Canada
Screws holding the C Hubs onto the axle also seem to work loose after a while. Lost a few, but now always check on it.
04-08-2012, 02:57 AM | #5 |
MODERATOR Join Date: Oct 2010 Location: RC Land
| Re: The Rock Bus
Loc-Tite is your friend with all RC's and a staple to every tool box. |
04-08-2012, 11:28 PM | #6 |
| Re: The Rock Bus
i like loctite but i have also used the stuff and stripped the hardware when i needed to do maintainence and i hate getting the dremel out. hell this rig is still sitting on the top shelf with the stock esc plug and yet to have power put to it so i havent found out whats gonna loosen up other than what has been mentioned. i have touched every piece of hardware on the wraith though and everything is tight but with the way my scalers are going im not even sure this rig will ever get run.
04-09-2012, 09:18 AM | #7 | |
| Re: The Rock Bus Quote:
I tend to keep my micro torch handy and full all the time. With the tiny amount of Loc-Tite that gets used and the tiny hardware (screws,bolts and nuts) involved it takes very minimal heating/contact. With the micro torch on high using the pin point solder tip, it takes but only a brief instant of contact to produce a tiny puff of smoke when the Loc-Tite releases and the hardware comes off/out easily just like when it was installed. Sometimes I use the micro torch with no solder tip and just the very tip of open flame. That way is even faster, but takes a bit of practice to get the timing right so you do not melt any plastic. But..... Once you get the timing right.... The Loc-Tite will always release itself before the temperature needed to melt plastic. I guess you could release Loc-Tite with a regular soldering iron too.... But I have never tried. I tend to Loc-Tite everything. I never even attempt to remove a Loc-Tited piece without heat. My methods in order are..... (I have a spare junk set of stripped hex tools and drivers) Using a junk hex or driver and the micro torch with open flame I briefly heat the tip of tool, remove from flame and press it to the hardware needed to be removed, almost instantly the tiny puff of smoke from the Loc-Tite releasing will appear and you're all set to switch to a good tool and remove hardware. Secondly I will use the solder tip in the micro torch and approach removal that way. Thirdly for any stubborn hardware I resort to open flame directly to the hardware. Some Loc-Tite are designed to ONLY come loose with heat applied. But a little touch of heat will surely work to easily release ALL types of Loc-Tite. | |
04-09-2012, 10:43 AM | #8 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Love the yellow, OP! Mine will be eventually be that color to match my 1:1 JK Unlimited. | |
04-14-2012, 02:38 PM | #9 |
| Re: The Rock Bus |
The Rock Bus - Similar Threads | ||||
the cool bus | excav8rguy | Paint and Body | 3 | 05-31-2010 05:19 PM |
The short bus | derwood21 | RCC Speed Shootout | 17 | 11-23-2009 06:57 PM |
School Is In!!! Now get on the Bus!! | adamtrax | HPI Wheely King | 23 | 09-16-2007 03:57 PM |
Skool Bus | KENNYKILLER14 | Paint and Body | 8 | 05-10-2007 12:47 AM |
The nylint bus! | holycaveman | General Crawlers | 37 | 03-27-2007 02:09 PM |
