04-15-2012, 03:05 PM | #1 |
| How Hot Are You Running Your Wraith?
Well usually I do the 5 second rule if I can't keep my finger on the can that long without burning myself I definitely have over geared. Recently I upgraded some essential drive line pieces on my Wraith kit namely Supershafty's Beefy top shaft for the Wraith as well as installing the RR Slash Gen3 Steel Slipper which is a 56T mod8 and I coupled that with a RR steel mod 8 14T pinion. Running gear: BRXL w/CM 16T on 3s 40C 1550mah MaxAmps pack from my MERV days. CC BEC @ 7.4V on a 7950TH R2j stainless uppers CAC Aluminum EZ Locks 2.2 on R35 Ripsaws fronts weighted 8 oz each not including wheels/CI Closed Cell soft foams/tires. Rears weighted 4 oz each not including wheels/CI Closed Cell med foams. Aluminum Roof, side, and cargo panels. -DMG and CI Electronics and battery moved to hood. Supershafty top shaft/steel RR tranny gears and slipper/MIP shafts Losi 4" 60wt front 50wt rear white springs all around. VP Titanium tie rod/drag Axial aluminum XR knuckles/C's All in all this thing is a beast rock hopping and tire shreading! With all that aluminum and steel it doesn't weigh as much as my other 2.2 TT comp rig. I'm guessing in the ballpark of 7 lbs. RTR. Now with 14/56 gearing the battery puffs a bit after LVC and the motor is usually around high 90's to around 110* I'm assuming this is ok? How hot is everyone else running brushed or sensored brushless? |
04-15-2012, 03:22 PM | #2 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: How Hot Are You Running Your Wraith?
I run my Wraith on 5000mah 3s 40-50c 21t Titan geared 23/80 and it hardly gets warm at all. Even crawling and when it hour bound up.
04-15-2012, 04:01 PM | #3 |
i have a hh 25t torque master pro. i run a 62/10 and it runs very very cool. most of the time you can barely even feel it getting warm.
04-15-2012, 04:15 PM | #4 |
Rock Stacker Join Date: Dec 2011 Location: calverton
been running titan 12t's until i can afford to go brushless, with 21/80 gearing and 2s 5000mah batteries. it gets a little hotter then i'd like. but these motors are cheap and temporary, so it's okay. i just ordered some 3s batteries so im sure it'll get even hotter.
04-15-2012, 06:33 PM | #5 |
RCC Addict Join Date: May 2009 Location: Weston
I run 3s 5000mah 40c packs a MMP and a Ballistic 4.5 550 with 15/56 gearing. It's the speed I want but runs very hot. The ESC is naked and in a closed box so toward the end of the battery it shuts down on its own due to heat. The motor runs about 115 - 120. I might drop down a tooth or two on the pinion and see how it goes.
04-15-2012, 07:15 PM | #6 |
Rock Crawler Join Date: Nov 2008 Location: missoula
I was running 14 56 on 3s ran great but motor was way to hot to touch by end of pack.
04-16-2012, 09:06 AM | #7 |
I'm running HH 35T machine wound with BRXL mostly on 2s 5000mah geared 87/16 and the motor doesn't even get warm. On 3s 2250mah it gets a little warm but doesn't get run for as long of a duration between breaks.
How Hot Are You Running Your Wraith? - Similar Threads | ||||
CC S-2 Running HOT! | TrailDawg362 | Electronics | 0 | 07-06-2011 06:12 PM |
novak 21 running hot in lcc | nitrorube | Team Losi Comp Crawler | 5 | 10-26-2009 07:44 PM |
Motor,esc and batt running hot.. | dr_rookie7 | Electronics | 13 | 09-26-2009 10:36 AM |
motor running HOT | dhoffroad | Electronics | 2 | 08-02-2007 10:15 PM |
Moter running UBER hot HELP! | BrandonW | Newbie General | 12 | 05-26-2006 07:50 AM |
