10-05-2012, 07:23 PM | #81 |
Going Fast Join Date: May 2011 Location: Hazzard County
| Re: Cole's Crawlmaro
Thank you to all who voted for Crawlmaro for TTC. Sadly something in the electronics gave up after the 4th event. But I DID prove that you don't need a custom one off chassis to compete. The Crawlmaro performed better than expected. In the 4 events Crawlmaro participated in, here is how it stacked up to the very best of RCC... Frame Twister 3rd Obstacle Course 11th Hill Climb 2nd Mud Bog 1st Up until this point in TTC, Crawlmaro was in 1st place with 43 points. With Chino63 in 2nd with 41 points. To all the wraith owners out there, Don't ever let someone with a custom chassis tell you your a ****. If they do, just inform them of the 2012 Top Truck Challenge! Now on to the pics!!!!!! (Most pics courtesy to (not me)) Frame Twister Obstacle Course |
10-05-2012, 07:34 PM | #82 |
Hill Climb Mud Bog |
10-05-2012, 07:44 PM | #83 |
Some poser shots |
10-06-2012, 12:35 PM | #84 |
Rock Crawler Join Date: Jul 2012 Location: In a van down by the river
What a sweet rig!!! Thanks for the pics of your w/p Tekin Pro... Just curious, how do you like the Savox servo? Seems most people run HiTec (myself included). The servo is one of the final pieces I need for my Wraith kit. I'm just building a standard wraith but metal body panels... Cheers and congrats on putting in a great showing at TTC! Todd Todd |
10-06-2012, 03:11 PM | #85 | |
| Re: Cole's Crawlmaro Quote:
Thanks Todd, I like the savox, just wish it had more torque. I may go to a 7980 hitec or the like. | |
10-08-2012, 07:39 AM | #86 |
Thanks Cole... HiTec it is!
12-02-2012, 07:57 PM | #87 |
A needed update, still beating the snot out of Crawlmaro, rear of the cage snapped but it actually didnt seem to affect anything. I've put Grey Vanquish housings on it f/r. Painted up the chubs and diff covers. Absolutely love the pro4 on 3s combined with the ax2 tranny. Will hopefully get a crappy Iphone vid up soon. |
12-04-2012, 07:10 PM | #88 |
While practicing my Tim Cameron Southern Buggy skills a bearing blew out on the front pinion gear. Sadly it did some machining of the Vp housing. Hopefully it will still go back together alright. (The shiny area was where the damage was done) |
12-05-2012, 10:29 AM | #89 |
Newbie Join Date: Nov 2012 Location: Madison, AL
Eeek. Very sick rig man. I hope that VP housing didn't bite the dust
12-05-2012, 11:13 AM | #90 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: Cole's Crawlmaro Doesn't it make a nice tearing, ratcheting noise when it does that? I'm waiting on my bearings to fix the exact same issue in the exact same housing... Fun times! |
12-05-2012, 11:16 AM | #91 |
| Re: Cole's Crawlmaro It should* be fine. The area that the gear hit shouldn't affect the functionality of the housing. When the bearing goes, it allows the yoke to move forward toward the drive shaft. The real risk is to the gears, since the movement allows them to slip, and thereby shred one another. At least that's the case with my housing. I stopped as soon as I heard the gears ratcheting, so the 'machining' on the interior of my housing is minimal. My gears should be fine too, but you can plainly see where they began to sheer one another (no more than a fraction of a mm). The area where the bearing sits wasn't damaged at all.
12-05-2012, 11:50 AM | #92 |
I also stopped when I heard the ratchet sound. Gears look fine. Scores the Vp locker slightly but didn't affect anything. Are you using any special bearings cephas?
12-05-2012, 12:55 PM | #93 |
RCC Addict Join Date: Sep 2009 Location: sacramento
digger ive lost that same bearing two diffrent times
12-05-2012, 04:29 PM | #94 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
I have lost that same bearing on mine also with the stock housing and ate up the plastic badly. I tried finding a bigger bearing to fit behind the pinion to keep that from happening but have not found one that will fit the HD gears and fit tightly in the housings. I wish the HD gears had the bigger diameter behind the teeth like the standard gears have. You should be fine. Just put some quality bearings in it. I found running high drag brake with high speed seems to make this problem worse. |
12-05-2012, 05:42 PM | #95 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
I have blew inner and outer pinion bearings in the front and rear axles multiple times. I now run traxxas bushings instead. Sounds ghetto, but this has fixed this PITA. Thought I would throw this out there. Later, Farmer |
12-05-2012, 11:02 PM | #96 | |
Anyway, I replaced the bearings that failed in the front housing with those Traxxas bearings. I didn't even get a battery through it before the bearings in the rear housing took a bear sized crap. LOL I am geared pretty low with over/under drive and RR gears in the tranny. Add that up with the HH 45t Torquemaster pro, and this is what happens to stock bearings. I'll leave the Traxxas bearings in and see how they fair against the Fast Eddy bearings, which should be here this week. I just beefed everything up too fast. LOL On the bright side, since I have broken it EVERY time I've driven it... it should be bullet proof before too long. | |
12-06-2012, 01:44 PM | #97 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
very cool concept and execution. I've been chewing on the idea of a Mopar crawler, and this might push me over the edge... we can't have the bow tie's having all the fun now can we?
12-06-2012, 02:02 PM | #98 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Very nice job.
12-06-2012, 05:18 PM | #99 |
Thanks guys, this was a Fast Eddy bearing and the first pinion gear bearing that I've ever blown. If this happens a couple more times I may try bushings.
12-06-2012, 07:32 PM | #100 | |
The Traxxas part number is #5116 [Ball Bearings, Blue Rubber Shield (5x11x4mm)(2)] Here's the pictures I promised of our 'hole in the wall' LHS. Really nice guys, but it is uber small. Last edited by TheScaleAddict; 12-06-2012 at 07:53 PM. | |
Cole's Crawlmaro - Similar Threads | ||||
My version of Crawlmaro | ati2de22 | 2.2 Scale Rigs | 30 | 07-04-2012 09:02 AM |
Crawlmaro | adamargue | General Scale Talk | 16 | 10-13-2011 09:33 PM |
