07-06-2012, 04:05 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: San Antonio TX
| Slop with Super Shaftys??
Is there supposed to be slop with the super shafts mod ? Feels real cheap, the stock was tighter. Thanks Sorry for the link, I dont know how to put it in the Message itself. 042146dc.mp4 video by choppermech11 - Photobucket |
07-06-2012, 05:48 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
| Re: Slop with Super Shaftys??
Looks like your missing the spacer. Mine has no slop. Later, Farmer |
07-06-2012, 06:22 PM | #3 |
Ummm, what spacer? I got a shaft, spring, nut 2 pins and a black adapter for the spring. Do you have a pic of the spacer and where does it go?
07-06-2012, 06:52 PM | #4 |
Did you specify whether you had a writh or ax10 transmission. Get ahold of Rick, he will take care of you. The wraith trans uses a spacer to take up the slop. U could use a bearing also. Just about anything will work. Later, Farmer |
07-06-2012, 07:31 PM | #5 |
Thanks! I'll email Rick, I'm sure I've got a bearing. Just didn't know if it was normal or not..
07-07-2012, 12:48 PM | #6 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
Look Here at "HARLEYS" Build thread Harley's Axial Wraith Build - Jimmy's 4x4 Ultra 4 KOH Style You need another 5mm bearing and then the stock spacer Regards Rick |
Slop with Super Shaftys?? - Similar Threads | ||||
Fix your rear axle slop on the super cheap! | mdchris | Axial XR10 | 14 | 03-08-2012 10:42 AM |
Slop in Super Bully axles.. | bpd964 | RC4WD Bully | 33 | 06-18-2011 12:58 PM |
LCC setups what is everyone running on there shaftys. | zr600 | Team Losi Comp Crawler | 2 | 11-14-2010 02:45 PM |
Bored of the shaftys, its Time for MOA | Indaflow | General Crawlers | 8 | 06-17-2009 09:16 AM |
