07-25-2012, 02:25 PM | #21 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
| Re: Aluminum Highland crawlers locked won't stay tight!!!!
Hey Harley, draw up those stage 3 lockers and I will get them made I know you can do it Later, Farmer |
07-25-2012, 02:59 PM | #22 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
The one downside of a no slop locker is that the set screw can come loose. I have a few sets of both highlands and felesnfest and they both come loose occasionally. More red loctite would probably fix it but then they may never come out. I am thinking of switching back to the bulletproof HR steel spools. Never had a problem with those.
07-25-2012, 03:21 PM | #23 | |
| Re: Aluminum Highland crawlers locked won't stay tight!!!! Quote:
Later, Farmer | |
07-25-2012, 03:30 PM | #24 |
| Re: Aluminum Highland crawlers locked won't stay tight!!!! |
07-25-2012, 04:46 PM | #25 |
07-25-2012, 08:27 PM | #26 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
I don't know if there is enough room to increase the screw size but I love my hr spools. Had em a little bit and slop is minimal. |
07-25-2012, 08:49 PM | #27 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
I vote ya just throw that chunk of doo doo in the garbage and buy a Summit. |
07-26-2012, 04:47 AM | #28 |
07-26-2012, 06:59 AM | #29 |
Ok, thinking of pulling the trigger on the HR units. My issue is I need to know if there would be enough room for me to drill and tap to 4-40, since my ring gears are drilled and counter sunk for that hardware Thanks in advance for any info on this Later, Farmer |
07-26-2012, 04:34 PM | #30 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Not much meat around the mounting holes, but you can make that determination. |
07-26-2012, 05:05 PM | #31 |
Thanks a lot man Wow, I was hoping for a little more meat. Looks like I need to just get some in hand. Stupid Wraith....... Thanks, Farmer |
07-27-2012, 10:24 AM | #32 | |
07-30-2012, 10:09 AM | #33 |
Little update, rear is still holding. Front is completely junk. Took it out for a bit between courses at our comp and failure within 5 minutes. I also decided to put the beast in the river Looks like I have time to corosion x everything now Probably should have done that already......lol. Someone please build a strong locker. Maybe they will.......... Later, Farmer |
07-30-2012, 10:55 AM | #34 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
I will see if I can get my hands on some of the Green Mopar thread locker we have at work. It is stronger than the red, maybe this will work. Im still impressed how far you skied on one flip-flop across the mud to save your rig out of the river yesturday....that was awesome! Truck in the river......not awesome.. |
07-30-2012, 11:09 AM | #35 | |
07-30-2012, 11:43 AM | #36 | |
Later, Farmer | |
07-30-2012, 07:56 PM | #37 | |
Good deal Farmer, im sure the hot subi helped. I would still drop it in some rice till your corrosion x shows up, like I said the tail lights were starting to blink when you pulled the battery. | |
Aluminum Highland crawlers locked won't stay tight!!!! - Similar Threads | ||||
Lake County Rock Crawlers,Highland Springs #3. | Straightjacket | Competitions | 26 | 10-12-2009 10:48 PM |
Axle c's wont stay tight! | rottenbelly | Axial AX-10 Scorpion | 20 | 03-26-2009 12:16 PM |
