07-24-2012, 11:29 AM | #1 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
| Aluminum Highland crawlers locked won't stay tight!!!!
Well I thought these would work, but don't. I have the aluminum version with the 4-40 hardware. I did notice that the clamping piece has a spot for the shafts to fit in, but they go the wrong way. I looked back in his thread and saw some guys were lucky enough to get replacements. I have ran felsenfests and rcp with no luck. I also used red locktite with no success. That's with degreasing and a 48 hour cure time. I know there are guys throwing more power or the same I am. Can anyone help me. I finally have the rest of the rig holding together, these lockers keep haunting me though. Thanks, Farmer |
07-24-2012, 11:47 AM | #2 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: Aluminum Highland crawlers locked won't stay tight!!!!
thats crazy that red loctite is coming loose. i was one of the first to get the steel locker and i havnt had to touch it since i set it up, and that was with blue loctite. the tang in my is flat on both sides, no grove for the shafts. im running 4s with a 26t crawlmaster. sorry im no help. |
07-24-2012, 11:49 AM | #3 | |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: Aluminum Highland crawlers locked won't stay tight!!!! Quote:
07-24-2012, 11:50 AM | #4 |
do your axles wobble?
07-24-2012, 11:57 AM | #5 |
My vp cvd's should be here this week and I will give them a try. The universals were brand new. Later, Farmer |
07-24-2012, 12:00 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
I am also running aluminum with blue loctite, no replacement tangs, and no problems, front or rear. Not sure what to say next though....?.. Sorry farmer.
07-24-2012, 12:33 PM | #7 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
Dumb question, but are you sure they are engaging far enough into the locker? Have you tried countersinking a small divot where the screw locks it down?
07-24-2012, 01:01 PM | #8 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
my aluminum locker has never come loose, with blue loctite, but the steel in the front has to be tightened after every couse |
07-24-2012, 05:28 PM | #9 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Another thing to check is the condition of the set screw. Set screws have a cup or other shape on the end that digs into the surface it is supposed to keep tight. If the screw has been tightned and loosened multiple times this is most likely worn off and the end of the set screw will look completely flat. It would be a good idea to replace them.
07-24-2012, 05:31 PM | #10 |
Doesn't seem to me it's worth it for the only advantage it gives over a solid 1 piece spool.. Not if it's got the possibility of loosening. To me anyway, reliability is important.
07-24-2012, 09:23 PM | #11 |
Sucks man... I'm sure you'll find something soon though.
07-25-2012, 08:37 AM | #12 |
Rock Crawler Join Date: May 2007 Location: Prescott
I also ran the aluminum versions and they both have come loose regardless of what loctite I used. They are both chewed up and worthless now. I have moved on to HR lockers.
07-25-2012, 09:04 AM | #13 | |
Later, Farmer | |
07-25-2012, 09:14 AM | #14 |
| Re: Aluminum Highland crawlers locked won't stay tight!!!! This is what we have to do on the higher power Ebike drivetrains. If we don't dimple the shaft or just weld them all together they constantly come loose. I say give dimples a shot if you are out of options.
07-25-2012, 01:13 PM | #15 |
One piece lockers FTW! |
07-25-2012, 01:38 PM | #16 |
| Re: Aluminum Highland crawlers locked won't stay tight!!!! |
07-25-2012, 01:40 PM | #17 |
| Re: Aluminum Highland crawlers locked won't stay tight!!!! Oh, I like your other suggestion......Lincoln Locker!! |
07-25-2012, 01:48 PM | #18 |
Wish bonus line lockers were still made. Sorry to hear farmer. Me personally, I don't trust locker that use set screws to keep things in place. Last edited by eric113; 07-25-2012 at 02:58 PM. |
07-25-2012, 01:48 PM | #19 |
The only problem with that is taking it apart without getting out the angle grinder! Lincoln Locker, lol!
07-25-2012, 01:52 PM | #20 |
Aluminum Highland crawlers locked won't stay tight!!!! - Similar Threads | ||||
Lake County Rock Crawlers,Highland Springs #3. | Straightjacket | Competitions | 26 | 10-12-2009 10:48 PM |
Axle c's wont stay tight! | rottenbelly | Axial AX-10 Scorpion | 20 | 03-26-2009 12:16 PM |
