08-13-2012, 08:38 AM | #1 |
| Universals up front and dog bones out back?
I've got the hankerin' for some 4 wheel steering. Seeing as I'm a cheapskate I was wondering if I could swap the front stuff to the back, and then build up the front. My idea is this: Rear: Use stock AS-2 servo out back - have Use stock c-hubs out back - have Use stock knuckles out back - have Use front dog bones out back - have Home made steering link and drag bar - have Servo plate and ears - buy Front: Hitec 5995tg - have Axial universals - buy Aluminum c-hubs (VP or ST) - buy Aluminum knuckles (VP or ST) - buy Home made steering link and drag bar - make So far from my experience with the Wraith most of the load and stress is on the front from the bouncing along and crashing. The rear seems to get less stress. Also, for my 4WS setup I'd probably have the rear set with a good amount of dual rate and expo so the rear servo only cranks all the way when the steering wheel is cranked all the way. Are there any down sides to reusing the old stuff in the back? Aside from the fact that it's old and worn and would need to be replaced at some point? |
08-13-2012, 08:17 PM | #2 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: Universals up front and dog bones out back?
Everything from the front will work on the back. The only thing with rear steer is you loose a lot of suspension travel because the servo hits the bottom of the cage in the back. The only good way to do it is to do a chassis mounted servo in the rear, which requires a fair amount of cutting. I really don't thinks it worth it. Plus you will need to solder a BEC on to your ESC so it can handle the extra amp draw and doesn't brown out. Then you have the added wear of all the extra moving parts. AND you'll need a pretty high end radio that can do steering mixes. Defiantly not a cheap upgrade.
08-13-2012, 08:21 PM | #3 | |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
| Re: Universals up front and dog bones out back? Quote:
08-13-2012, 08:24 PM | #4 |
| Re: Universals up front and dog bones out back? Yup same here, then I took it off!!! Its kinda useless if you drive faster than a walking pace. Don't get me wrong, its bad ass looking, but other than sheer entertainment value.....its useless.
08-13-2012, 08:31 PM | #5 |
| Re: Universals up front and dog bones out back? I'm going to be running the crawlmaster 13 turn by HH so I think it should be a blast, Harley sure liked it, even if I hate it I'll leave it on bc you never know when you might need it while comping
08-13-2012, 08:52 PM | #6 |
Thanks guys. My main thinking was to outfit the truck for more G6 type comps. At this point I'm thinking that a dig setup might be better suited to making the truck more maneuverable. I suppose I can always do the upgrades I plan and if I have enough parts left over I could do the rear steer setup. For now you've convinced me to just stick with front steering. |
08-13-2012, 08:58 PM | #7 | |
08-13-2012, 10:30 PM | #8 | |
Pebble Pounder Join Date: Jun 2011 Location: Sonoma, Ca
MADE BY CFM | |
08-13-2012, 11:11 PM | #9 |
| Re: Universals up front and dog bones out back? cool ive wanted pics of how to mount that crap for a while now, looks like ill be getting ahold of that company when i get to that part of my build |
Universals up front and dog bones out back? - Similar Threads | ||||
dog bones | sivad | Tamiya XC/CC01 | 5 | 01-22-2011 10:36 AM |
Dog Bones? | pbarsamian | General Crawlers | 6 | 04-09-2010 09:21 AM |
dog bones | newbe5.9 | EnRoute Berg | 11 | 12-13-2009 02:34 PM |
