10-02-2012, 12:10 AM | #1 |
Newbie Join Date: Sep 2012 Location: kauai
| wraith esc no throttle problems
ive seen other threads with this problem but none of um seemed to help so here my problem i was doing some minor crawling with my rtr axial wraith all stock running nimh battery 3000mah fully charged so while i was crawling i had a call and was talking on my phone for like 5 min and my wraith was just sitting on some rocks while i was talking and after i was done went to play and no throttle but steering works fine. so i turned it on and off no dice removed the battery charged it again still doesn't work brand new battery also i let it sit for a while still no bueno didn't get wet or anything so took it apart checked all the connections on the esc motor battery receiver still nothing but steering works fine tried binding again playing with the switches still nothing so then i tried to recalibrate it then i noticed that when i turn it on there is no second set of beeps nothing so i tried again esc turns on beeps first time light turn red then green but still no second beeps so i turn it off again hold down the trigger on the remote and still no second set of beeps cant even calibrate it at all also i checked the receiver to make sure it working on another rc and it works fine so does anyone have any idea of whats going on? or did anybody experience the same problem? or is it a manufactures defect or something? any ideas would be much appreciated thanks stock rtr axial wraith about 2 months old |
10-02-2012, 06:21 AM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
| Re: wraith esc no throttle problems
I had a similar issue with the stock speed control in a wraith. Went to the lhs, they called axial and axial is sending a new one out. They didn't even want the old one back. It was a month old with only two full packs through it. Excellent customer service.
10-02-2012, 04:23 PM | #3 |
Newbie Join Date: Oct 2012 Location: Hawaii
I have the same problem but mine wont even do the multi-tone and i noticed that the orange/red light on the esc blinks in the tone of the multi tone and after that when i press the throttle the green light goes on like normal but the wraith doesnt move or make the usual sound it makes when i push the throttle, its fully stock running a duratrax 5000 mah nimh battery, i had it for about two months.
10-02-2012, 04:32 PM | #4 |
Newbie Join Date: Sep 2012 Location: BREA
it proably a bad connection or just a bad motor. mine had same problem until i droped a new motor into it and worked right away
11-14-2012, 10:02 AM | #5 |
Newbie Join Date: Nov 2012 Location: Madison, AL
Did you get it figured out?
wraith esc no throttle problems - Similar Threads | ||||
Throttle problems | sixhundred71 | Axial Wraith | 4 | 01-01-2012 07:12 PM |
Wraith throttle problems | sixhundred71 | Axial Wraith | 4 | 12-31-2011 08:53 PM |
new wraith esc problems | mrallen0 | Axial Wraith | 3 | 12-03-2011 09:02 PM |
stock Wraith ESC steering but no throttle | boulder | Electronics | 28 | 11-21-2011 02:35 AM |
Throttle and ESC Problems | dabomb5756 | General Crawlers | 4 | 12-28-2005 09:21 AM |
