12-30-2011, 05:25 AM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
| Wraith throttle problems
Just got a wraith out of the box and when I press the throttle all the way in it doesn't respond then when I let it go it jumps forward a little bit . It seems that when I ease my way into the throttle it works. Is it supposed to be like that. Brand new batteries in the remote. It just doesn't seem to be that responsive. Pleas help. |
12-30-2011, 08:43 AM | #2 |
Rock Stacker Join Date: Nov 2007 Location: Billings
| Re: Wraith throttle problems
You need to include for info. Such as what size battery lipo or nimh. But from the lack of info I can only guess that you are using a nimh. Your problem is the voltage drop using nimh is so great at full throttle that the esc hits lipo cutoff as its set from the factory this way.
12-30-2011, 04:05 PM | #3 |
The battery is a 3200 nimh. And how do I stop it from doing that. I don't plan on going lipo.
12-31-2011, 08:47 PM | #4 |
The esc is made by castle and is somewhat programable through there castle link. It's roughly 30 bucks from a lhs here in the states. If you plan on staying in rc it is well worth the money. When you buy other castle products (you will) you can change the settings on almost everything. I have read of people changing it without the castle link but Idk. Maybe your lhs can help??
12-31-2011, 08:53 PM | #5 |
Rock Stacker Join Date: Mar 2010 Location: Fargo
Mine I just got did something similar but I was running lipo. I talked to axial and ended up sending the esc in. Maybe there was a bad batch of esc's.
Wraith throttle problems - Similar Threads | ||||
new wraith esc problems | mrallen0 | Axial Wraith | 3 | 12-03-2011 09:02 PM |
stock Wraith ESC steering but no throttle | boulder | Electronics | 28 | 11-21-2011 02:35 AM |
problems with steering and throttle, beyond my knowledge | Finnigan182 | Electronics | 7 | 02-26-2011 07:37 PM |
Throttle and ESC Problems | dabomb5756 | General Crawlers | 4 | 12-28-2005 09:21 AM |
need help fixing remote... throttle problems | badhoopty | General Crawlers | 4 | 08-16-2005 08:28 AM |
