12-04-2012, 03:20 PM | #1 |
Rock Crawler Join Date: Mar 2009 Location: East TN
| A different center diff
I was wondering how to make a wraith axle with the diff in the center? The catch is for the axle to have both long sides on it (like a super). Any help on this is much appreciated. Thanks! |
12-04-2012, 03:39 PM | #2 |
Newbie Join Date: Jan 2012 Location: quebec
| Re: A different center diff
take scx10/ax10 axles. less wide but diff is in the center. it makes the wraith look more scale too
12-04-2012, 03:59 PM | #3 |
Thanks but I dont think youre really following me on what I am trying to do. I am wanting a wider wraith axle. Thanks though
12-04-2012, 04:44 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Fairbanks, AK
CFM Makes awesome stuff! I'm sure that he'll make it exactly the way that you want. Carter Fab & Machine - Home "Ultimate 9"axle housings UPDATED PICS 4/01 post#2 |
12-04-2012, 06:28 PM | #5 |
Thanks ill check them out. I was hoping to get details so I could make it myself.
12-05-2012, 05:12 PM | #6 |
Bump for some "how to:"
12-06-2012, 12:20 PM | #7 |
Rock Stacker Join Date: Apr 2012 Location: Abbotsford, BC
Get two complete diffs and split each right in the middle of the pumpkin. Glue the two long sides together and furnish with all the long hardware. Reinforce it like 1:1 guys do with a strap/brace from side to side and maybe a ring around the pinion input. An aluminum diff cover would help support it too.
12-06-2012, 02:09 PM | #8 |
That sounds like it'd likely open up on the bottom. Especially with any kind of abuse or jump landings.
12-06-2012, 02:28 PM | #9 |
Quarry Creeper Join Date: Sep 2012 Location: Baltimore
Why would you need an axle wider than the ar60?
12-06-2012, 06:08 PM | #10 |
Because I need axles that let 40 series roc loks sit outside the body of a 1/6 jeep. I am currently making and welding up some tubed emaxx solid axles. But I like the ar60 better, so I'll give it a whirl. I think I've finally collected my ideas so I can start sorting through them. Thanks!
12-07-2012, 02:08 PM | #11 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
Make some beef tubes and do something similar to the XR super axles. Look in the super class section and look at some of the super XR builds. They are grafting housings together, also Christhebatteryman is making extended delrin beef tubes that might work for your application.
12-07-2012, 03:17 PM | #12 |
Rock Crawler Join Date: Jan 2010 Location: SOUTH CRAWLINA
Here ia another option, has everything you need. Aluminum Rear Centered Axle Housing for Axial Wraith (Black) |
12-08-2012, 11:33 AM | #13 |
Thanks ranger. I'll check into that section. Thanks!
A different center diff - Similar Threads | ||||
has anyone tried a center diff? | joshII | Formula Offroad | 3 | 06-08-2011 05:42 PM |
My Center Diff E-Maxx | skellyo | Non Crawler RC's | 2 | 01-18-2009 12:38 PM |
unloading center diff | savageracer312 | Tamiya TLT Crawlers | 5 | 02-25-2006 08:34 AM |
1/8 scale buggie diff for center | xtremraptor | Traxxas Crawlers | 12 | 01-03-2006 09:25 AM |
how do i lock the center diff? | Vitamin_J | XTM Crawler | 1 | 01-15-2005 12:51 AM |
