12-16-2012, 10:48 AM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
| two speed trans question
Is anyone running a pro 4 on the two speed transmission from rc4wd? If so how it holding up to the power? I am currently running a pro4 and have developed a clicking noise in my trans and seem to make it go away so I'm lookinv at just r replacing it!
12-16-2012, 10:49 AM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: two speed trans question
Might just be a bearing going out.
12-16-2012, 10:54 AM | #3 |
Already replaced all the bearings with a fast eddy bearing kit! I thought maybe after I put the pro 4 in I would just run it till lets go but hasn't happened yet.
12-16-2012, 10:56 AM | #4 |
| Re: two speed trans question , with a Pro 4 it will let go some day.
12-16-2012, 11:02 AM | #5 |
| Re: two speed trans question |
12-16-2012, 02:43 PM | #6 |
Newbie Join Date: Apr 2011 Location: lancaster
it's a strong transmission, im not running a pro4 but I am running a 4 pole 2800 kv motor and it runs great so far |
12-16-2012, 06:50 PM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
I am running a pro4 3300 in my wraith with the 2speed rc4wd trans. I have not had any problems other than the spur screws falling out. I am geared 15/60 and probably have 20+ packs through it no problems yet. There is a thread in the general section that lists the bearings required for the rc4wd trans.
12-16-2012, 07:52 PM | #8 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
A friend has a 3300 Pro4 with the AX2 trans in his Wraith and so far so good, i have some video of it in some loose hill, i'll post it tomorrow
12-17-2012, 11:22 AM | #9 |
Im just gonna run this one till it grenades! I dont know else to try and replace on it and the funniest part is that the noise comes and goes.
12-17-2012, 12:48 PM | #10 |
Here's a friend's Wraith with the Pro4 3300 on 3S and the AX2 trans: |
12-17-2012, 06:24 PM | #11 |
Rock Crawler Join Date: Apr 2010 Location: America
If it comes and goes its a bearing or a shaft output problem and ur best bet is take it apart clean it take fine grit sand paper to everything and pack grease every did it to my scx10 tranny and no more squeaks or squalls.
two speed trans question - Similar Threads | ||||
2 speed trans | DIZZE004 | General Scale Talk | 0 | 11-07-2010 12:27 PM |
What 2 speed trans to use? | McCready | 2.2 Scale Rigs | 2 | 08-13-2010 07:13 AM |
SCX10 Trans question (speed related) | devestator_x | Axial SCX-10 | 4 | 11-30-2009 04:28 PM |
Two-speed trans options? | JavelinSST390 | General Scale Talk | 1 | 03-18-2009 12:12 PM |
