12-18-2012, 02:54 PM | #1 |
Newbie Join Date: Dec 2012 Location: Arlington
| Steering problems, please help!
Ok, I'm building an axial wraith i have finished it and I put the aluminum steering tie rods on it and it has a bunch of over steer, anyone have a solution? or have the same problem? it wants to turn left or right but still goes forward I even added lots of weight to the front tires to cancel that along with keeping the front end down while crawling. I am new to this and I just need some input, thanks! heres a couple pictures of my project and a link that shows our outdoor crawl HonkerCrawl Photos by shopteacher | Photobucket |
12-18-2012, 02:58 PM | #2 |
| Re: Steering problems, please help!
because of the locked diffs, these trucks do not have great steering. You could add Overdrive gears in the front and Underdrive gears in the rear, that will greatly increase turning radius. |
12-18-2012, 03:05 PM | #3 |
Getting some decent tires would help too...
12-18-2012, 04:34 PM | #4 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Steering problems, please help! Does this only apply to crawling? I always wondered why a person would have different gears front and rear? I thought that was bad? Maybe it is bad if you only want speed?
12-18-2012, 05:41 PM | #5 | |
Rock Stacker Join Date: Apr 2012 Location: eastern gorge
| Re: Steering problems, please help! Quote:
what tires do you suggest? we have a set of ripsaws that came with it... the ones on it are beadlock rims and tires from a redcat has anyone done a rear steer for the wraith? | |
12-18-2012, 05:45 PM | #6 |
He meant decrease. Adding od/ud gears greatly reduces the turning radius. Because the front wheels are spinning faster, it will pull itself around using the slower moving rear wheels as a kind of pivot point. Probably one of the best mods you can do to a non-dig shafty. It also greatly improves climbing ability. It does cause issues if you want to go fast though. |
12-18-2012, 06:00 PM | #7 |
Thanks for clearing this up Duuuuuuuude. It helps me understand much better. I want speed in my one Wraith and crawl ability in the other. So this is very useful info!! |
12-20-2012, 08:49 AM | #8 |
so would the gears or rear steer be the best way to go? he has the radio/receiver that would allow rear steer. it is a matter of knuckles, servo, etc. i did rear steer on my ax10 and it was amazing. mode 1:full rear/ mode2: 20% rear |
12-20-2012, 09:24 AM | #9 |
If you plan to comp at some point, no rear steer, it is not allowed. If you are just goofing off and having fun, go rear steer. The gears are helpful for more than turning though... |
12-20-2012, 07:06 PM | #10 |
Newbie Join Date: Jun 2012 Location: Salem, WV
Hi On the note of steering Is anyone using this from CKRC ? https://www.ckrccrawlers.com/ckrcs-s...d9e311ef2cf88d It looks like it would help out alot in tight spots crawling, especially with a higher torque servo Thanks Scott |
12-20-2012, 07:42 PM | #11 |
That is suicide!! LOL
12-20-2012, 09:10 PM | #12 |
You could make that at home in about 15 minutes and $4 worth of parts, minus the servo horn.
12-20-2012, 09:26 PM | #13 |
Newbie Join Date: Mar 2012 Location: PERKASIE
i run it on mine and love it. works really good i think
12-20-2012, 09:36 PM | #14 |
Newbie Join Date: Jan 2012 Location: Kamloops
That's a poor steering setup for various reasons. Harder on servos: gears, cases and horns. Unequal steering geometry side to side due to servo horn not being centered on axle which is undesireable for a few reasons. Last but not least the pictures they show on the site: my tie rod and drag link setup with Vanquish knuckles and Axial universals can turn that sharply also, when not moving........Axial universals will bind up at quite a bit less of an angle than shown when rotating (moving). Universals of whatever sort will always be the limiting factor in that case as none that I have seen can rotate at angles greater than a tie rod/drag link setup provides, so there's really only disadvantages to a suicide switch setup IMHO
12-20-2012, 09:53 PM | #15 | |
There is a reason nobody really uses that kind of steering setup. BV just explained why. | |
12-20-2012, 10:24 PM | #16 |
Good to know it is not worth trying!! or well $4 for trying |
12-20-2012, 10:27 PM | #17 |
| Re: Steering problems, please help! |
12-20-2012, 10:42 PM | #18 |
What bugs me even more are the claims of improved Ackerman. Ackerman angle is built into the steering arm radius and angle in relation to kingpin inclination, nothing to do with tie rod length, and is designed to provide toe out on turns based on the principal that the inside tire turns in a smaller arc than the outside tire. Correct angle helps greatly in low speed maneuvers (tight turns) by helping the tires to follow a different arc around a common pivot point . All I can see with the suicide setup is tie rod length changing as the servo travels upward in its arc from it's neutral (lowest) point and effectively getting shorter as the two steering links triangulate, causing toe in on turns, the opposite of what is desirable.
12-20-2012, 11:27 PM | #19 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Steering problems, please help! Yeah, do it in your crawler Wraith, Clay. As mentioned, it helps with climbing plus with a few blips of the throttle in a turn you can pull the frontend around faster. A poor man's dig.
12-22-2012, 01:30 AM | #20 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Steering problems, please help! - Similar Threads | ||||
steering problems | Fuzzynut23 | Axial AX-10 Scorpion | 10 | 12-15-2011 01:04 PM |
steering problems | fordlightning + jeep | Newbie General | 11 | 05-11-2011 05:28 AM |
Steering problems | tjcrawler | General Crawlers | 2 | 05-21-2006 09:51 PM |
Steering problems | dan1990xj | General Crawlers | 12 | 03-24-2006 10:17 AM |
Steering problems | Sean | General Crawlers | 8 | 10-18-2005 03:38 PM |
