Thread: Wraith Shock Mod
Old 01-12-2013, 12:59 PM   #1
Default Wraith Shock Mod
Hey Fellas,
I found out this new mod since my wraith sat like a monster truck. What you are gonna wanna do remove your shock from the front mount on your axle housing. Then unscrew your ends that you put your flanged balls in. Then put your shock on your link and screw your end back in. Hope you like this mod! Have fun out there on the course.
THEKrawlerKID4 is offline   Reply With Quote
Old 01-12-2013, 01:55 PM   #2
Default Re: Wraith Shock Mod
looks like it would put more stress on the link on full compression causing a rod end to rip out..
ROLANDROCKSHOP is offline   Reply With Quote
Old 01-12-2013, 02:07 PM   #3
Looks like it would also bind up... Dose it???
crazy81 is offline   Reply With Quote
Old 01-12-2013, 02:11 PM   #4
Nope! I dont have any probs with it!
Old 01-12-2013, 03:24 PM   #5
interesting. thanks for the idea
evan03 is offline   Reply With Quote
Old 01-12-2013, 06:23 PM   #6
Thats super interesting.. I had the same Idea, I ran a shock in the regular spot with it on the farthest forwar mount then a thin damper on the back mount hooked to the rod like you have it. Didn't really do anything but look cool, I'll try to find some pics.
Arctic Fire is offline   Reply With Quote
Old 01-12-2013, 07:20 PM   #7
Or you can purchase the droop kit it won't look like a monster truck at all. I bought a CKRC brand and it works perfect just saying. That looks like it would mess up your shock and eyelet on a big bump or fall.
Hi-Intentionz is offline   Reply With Quote
Old 01-12-2013, 07:43 PM   #8
How is the articulation?
ZippoMan is offline   Reply With Quote
Old 01-13-2013, 01:31 AM   #9
I havent really tested my articulation, but im only running the stock shocks. See this is free to do. If you buy the droop kit then you gotta spend money. Just trying to think smarter without using money!
Old 01-13-2013, 08:30 AM   #10
so you just did this "mod" without testing pro's/cons before posting it as good advice??
Old 01-13-2013, 10:51 AM   #11
yes i did! I got this mod from a friend and he runs this mod all day long and races with it and does crawling comps wit it! So im pretty sure its all good. He busted an aluminum driveshaft before he did anything with the shock mod!
Old 01-13-2013, 11:05 AM   #12
does your friend have a thread?
Old 01-13-2013, 01:54 PM   #13
Nah! But I can get him to comment on here for you!
Old 01-14-2013, 09:41 PM   #14
waiting
Conman is offline   Reply With Quote
Old 01-14-2013, 10:32 PM   #15
Like I said droop kit but you say it's free but haven't tested it I have the droop kit and tested it and its the test approved works like a charm. But free is better than nothing right .....
Old 01-14-2013, 11:00 PM   #16
I have seen some trick lower link mounted shocks.... but this....
gbean is offline   Reply With Quote
Old 01-15-2013, 12:47 AM   #17
For free you could take them fancy aluminum battery trays from axial and a dremel and make your own droop brackets. Way to try and come up with something though
Joshs4x4toyz is offline   Reply With Quote
Old 01-15-2013, 06:06 AM   #18
flip the lower shock mounts over.
Old 01-15-2013, 10:49 AM   #19
^^^ This
Boomstk74 is offline   Reply With Quote
Old 01-15-2013, 11:15 AM   #20
Based on the length it looks like it doesn't lower the truck much. I'd like to see what the ride height compares to do it that way or flipping the lower shock mounts. I did that and ride height is good and I feel like the mount is pretty solid.
ik632 is offline   Reply With Quote
Wraith Shock Mod - Similar Threads
Shock mod Sparky6307 Axial SCX-10 10 11-26-2012 08:28 AM
Shock cap mod Deezul General Crawlers 24 08-09-2011 08:56 PM
!!!!!!!!!!!!!!!shock cap mod!!!!!!!!!!!!!!!!! gatecreeper Newbie General 5 08-01-2011 10:31 PM
Cr-01 Shock Mod EL BARTO 1979 Tamiya CR-01 10 06-06-2008 10:42 AM
