01-13-2013, 06:40 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Whats my problem?
I was crawling this afternoon. Got almost to the top of out trail and the truck started glitching. kind of bouncing forward on its own. Ran fine for about 10 minutes prior. We stopped for a photo op. When I turned the truck back on, it kept doing it. To the point of out of control. I swapped out the battery. Exact same thing. Radio batteries are new Truck batteries were fully charged This is an all stock Wraith *I am new to electric cars any ideas? |
01-13-2013, 06:45 PM | #2 |
Newbie Join Date: Jan 2013 Location: THE RC ROCKS
| Re: Whats my problem?
Well the only thing that could be wrong is you lost connection to your car from your remote, or it can be that one of your electronics are coming loose! So check that, you can also just call Axial and they will fix it! Its under warranty!
01-13-2013, 06:50 PM | #3 |
I was thinking the same. Just happened about an hour ago and it's freezing in my garage. Almost seemed like a binding issue. NOT looking forward to opening up the electrics box This is a used rig and somewhat frankensteined together. Ran good for the last 2 days though. Just put new gears on this morning. |
01-13-2013, 07:17 PM | #4 |
| Re: Whats my problem? |
01-13-2013, 07:18 PM | #5 |
The electronics box isnt bad to open! just dont start unplugging stuff in it! Then you will get jacked up! But if you need any help let me no
01-13-2013, 07:26 PM | #6 |
I checked all connections. Didn't see any issues. Reset the fail safe. Seemed to fix it. for about 20 seconds. Then went back to crazy
01-13-2013, 07:28 PM | #7 |
Alright, I would contact Axial tomorrow and see what they can do! They are super cool guys and will be willing to help you!
01-13-2013, 07:47 PM | #8 |
Its fine at full throttle/full reverse. Man, I am sick of buying used rigs. |
01-13-2013, 11:10 PM | #9 |
Newbie Join Date: Jan 2012 Location: Roseville
I had what sounds to be the same issue. Installed a BEC and the issue was fixed.
01-14-2013, 07:31 AM | #10 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
If your running a brushed motor, you might want try wrapping the motor leads around each other. I read on some post to do that. It worked on my super.
01-14-2013, 07:54 AM | #11 |
I'll try that today^^^ Right before bed I tried a Spektrum receiver I had. Connections were extremely tight. I had to take needle nose to remove. I must have squezzed something just right because when I reinstalled into the Axial receiver, the glitch seemed to have stopped. I brught it with me to work today to mess with. |
01-18-2013, 06:52 PM | #12 |
Problem was not fixed. Did same thing after about 10 minutes. Got the Spektrum setup in it now. Appears to have been a bad Axial receiver. All working well....for now. *Axial radio for sale! cheap |
01-18-2013, 10:20 PM | #13 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
Are you using the stock Tamiya connector? I had the same problem, I Love Deans connectors, and haven't had any problems since i changed! |
01-18-2013, 10:44 PM | #14 |
External regulator seems to be the universal fix all for some reason. These rigs are only running one stinking servo. Glad you got it fixed |
01-19-2013, 07:26 AM | #15 |
Newbie Join Date: Jan 2013 Location: BR
i was gonna suggest a new receiver
01-19-2013, 05:49 PM | #16 |
Ran for over an hour today. No probs. Worked through 2 nimh batteries. Got my deans soldered on and lipo tested out on backyard rockyard. Good to go!
Whats my problem? - Similar Threads | ||||
Whats the problem with money orders? | Dostradamas | Chit Chat | 60 | 10-24-2012 06:43 PM |
RADIOS: Whats needed and whats a good price tag | losikid | Electronics | 3 | 02-08-2011 10:20 PM |
whats my problem??????? | crawlinlosi | Losi Mini-Rock Crawler | 4 | 10-26-2009 10:12 AM |
whats hot, whats not. post good and bad setups and products | TomEGunn | General Crawlers | 9 | 05-28-2009 07:29 PM |
Whats the problem? | hurricanemitch | Tires and Wheels | 8 | 03-30-2007 02:57 AM |
