01-20-2013, 03:24 PM | #1 |
Rock Stacker Join Date: Oct 2012 Location: in the woods
| electronics boxs
where do i find the right connector to be able to put my electronics boxs and light controller in the back of my wraith let me know thanks
01-20-2013, 05:42 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: electronics boxs
Servo extensions you mean?? Or?
01-20-2013, 05:45 PM | #3 |
i have a wraith and my wire for my front lights is too short to get to the back of my wraith
01-20-2013, 05:50 PM | #4 |
servo extensions should work, find one long enough. They are pretty much plug and play. Other wires like power are a different story. :P Custom wiring time!! If you can solder you should know how to do this.
01-20-2013, 06:45 PM | #5 |
Newbie Join Date: Dec 2012 Location: Houston
Servo/wire extensions... 2- 10 bucks depending on length.
01-20-2013, 08:01 PM | #6 |
Newbie Join Date: Nov 2012 Location: Central Maine
I made extensions to my RX wire using servo wire and BEC wires using 14 ga wire by soldering them and used a servo extension. I also spliced my glitch buster in with the light controller.
01-20-2013, 08:15 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
i did mine with an old traxxas servo cut the plug remove the white wire an solder to the wires comein from the light control with heay shrink. cheap an easy solution
electronics boxs - Similar Threads | ||||
where do people buy the electronics boxs? | FordFixer | Axial SCX-10 | 26 | 03-16-2012 10:35 PM |
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
electronics ? | glock35 | Newbie General | 9 | 07-01-2009 10:12 PM |
electronics | chimney | Electronics | 4 | 10-05-2006 02:23 PM |
