Thread: gearing question
Old 01-20-2013, 09:19 PM   #1
Default gearing question
im putting a 27t motor in my wraith and was going to go with a 84/15 gear set-up but was thing if stock is 80/20 would 84/15 be pretty much the same as stock?
id like to have good crawling but speed when i need it. thats why i thought 27t motor and 84/15 would be good. help keep motor from running hot but also give good torque with ok speed am i wrong ?
jkustomz28 is offline   Reply With Quote
Old 01-21-2013, 02:08 PM   #2
Default Re: gearing question
any input would be nice thanks
Old 01-21-2013, 04:19 PM   #3
Read this thread if you haven't already done so.
Choosing a motor and ESC for your Wraith - Gearing Added!
80/20 = 4:1 gear ratio
84/15 = 5.6:1 gear ratio
84/15 is a lower gear ration than 80/20
I would probably start out with a gear ration closer to 5:1, check temperatures and adjust if needed.
Depending on your motor you might be better off with 32P gears.
That would in 54/11 32p range to start.
k7zpj is offline   Reply With Quote
Old 01-21-2013, 04:35 PM   #4
On the 32 pitch you can go to the 56 and still get the cover back on. I'm running a 55T motor with 56/12 (4.666) ratio. Ran for more than an hour never got hot. Crawls great but for get the speed. It's about as fast as a trot.
BentMetaL is offline   Reply With Quote
Old 01-21-2013, 07:03 PM   #5
ok i kind of understand i wasnt seeing how to get the ratio but now im understanding I'm waiting on a 84t spur gear so i think im going to try a 80/17 which i understand to be a 4.70:1 ratio I'm just hoping it doesnt make my motor run to hot
Old 01-21-2013, 07:04 PM   #6
btw im running a 27t axial motor
Old 01-21-2013, 08:05 PM   #7
i tryed the 80/17 i think its still to fast im gonna try the 84/17 when my 84gets here
gearing question - Similar Threads
Gearing question Trentenowns Axial Wraith 3 09-23-2012 12:00 AM
Gearing question transambill Axial Wraith 6 01-29-2012 07:04 PM
gearing question 4x4boy General Crawlers 0 09-18-2011 07:20 PM
gearing question creepingcrawler Newbie General 6 01-13-2009 12:21 AM
Gearing question musicmaniac HPI Wheely King 4 08-08-2007 12:52 PM
