01-27-2013, 07:43 PM | #1 |
Rock Stacker Join Date: Jan 2013 Location: garden city
| drag brake
i know that on the stock ESC its adjustable so what are people running theyres at? mine seems weak it set at whatever stock is. just wanting to know what other people have set theres at?
01-27-2013, 07:51 PM | #2 |
| Re: drag brake
i have mine set a 100%. itl almost hold on near everywhere else it holds and doesnt roll i ran 100-213% on castle esc and liked it alot for craqwling i think the more the hold the better because as you get where you want you dont want it roll off when you let of to steer or think about whre your going next. |
01-27-2013, 07:59 PM | #3 |
| Re: drag brake
what is the factory setting? and will it make things run hotter if you have it set 100% or will it cut life span down any of the ESC or the motor? |
01-27-2013, 08:32 PM | #4 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
| Re: drag brake
With the stock motor no amount of drag brake will hold the truck still. Im not sure on the exact number its set on stock but its not high. Temperature wont be affected much if any. Nothing to worry about. Get a nice motor and turn it up!
01-27-2013, 08:40 PM | #5 |
| Re: drag brake
I've tried lots of difrent drag brake settings and haven't noticed any heat or less run time. Longevity who knows |
01-27-2013, 08:59 PM | #6 |
| Re: drag brake
im running a 27t motor and it doesnt hold itself in place on flat ground lol if there is no heat issue then ill bump it up to 100% and give it ago
drag brake - Similar Threads | ||||
ax-2 drag brake? | LS1Armyboy | Axial Wraith | 19 | 11-13-2012 02:57 PM |
Castle / AE-2 Drag Brake and Brake Power | ik632 | Electronics | 0 | 04-08-2012 07:47 AM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
Drag Brake?? | losimrc | Losi Mini-Rock Crawler | 1 | 07-08-2009 07:28 AM |
Throttle / Drag Brake / Brake Question | phatchantz | Newbie General | 5 | 05-19-2008 11:57 AM |
