02-27-2013, 09:18 PM | #1 |
Rock Stacker Join Date: Oct 2012 Location: birmingham
| LGFAB Skid Plate! Bolt on!
Her is our skid plate for your wraiths!! Bolt on and made of Stainless steel, it will not rust and provides awesome strength and helps keep you from high centering and protects your plastic skid. Check out our Thread in the vendor section for pricing and how to buy!! |
02-27-2013, 09:22 PM | #2 |
| Re: LGFAB Skid Plate! Bolt on!
looks awesome though im sorry to say it will rust. would like to see some more photos maybe from the sides and mounting points |
02-27-2013, 09:26 PM | #3 |
It is 100% stainless steel. Will not rust. Not irony stainless but real stainless. It mounts using the existing body mount locations on the side doors. |
02-27-2013, 09:57 PM | #4 |
That photo looks awesome. I like it. Would like to see one after a few months of hard use to see if it foes rust
02-28-2013, 06:41 AM | #5 |
will do, I have one on my personal truck... in the picture.. that I ran hard and wet a week or so ago.. It has been sitting ever since.. I will take a pic in a few days to show you..
02-28-2013, 06:45 AM | #6 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
it keeps you from high centering huh....
02-28-2013, 07:22 AM | #7 |
"HELPS keep you from high centering" It is not a magic worker, however it is a hard metal, which in my testing slides better on rock than aluminum, or plastic. Both of which gouge and hang up quite easily. Evan here is a pic i just took of the skid after sitting for a week. real stainless steel doesnt rust. The cheap stainless that most grills are made of rusts. because it has other metals in it. |
02-28-2013, 09:21 AM | #8 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
Whats the gauge on that...looks thin.
02-28-2013, 09:36 AM | #9 |
Rock Stacker Join Date: Dec 2012 Location: The desert mostly
| Re: LGFAB Skid Plate! Bolt on! |
02-28-2013, 12:37 PM | #10 |
It is 22G but you will not have any issues with the strength. It is pretty stout. Im pretty sure butter is the only TRUE method of eliminating High centering haha
02-28-2013, 12:41 PM | #11 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
What grade of "real" Stainless is it?
02-28-2013, 12:46 PM | #12 |
Im thinking more about dents in the skid maore than anything. Come down hard on one of the edges and it will bend..distorting the shape. Yes it looks real nice but I would want one out of 18 Gauge myself...Just sayin.
02-28-2013, 12:49 PM | #13 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
I think it would help sliding over rocks. From the side view I like the looks of the bgr sliders personally
02-28-2013, 08:22 PM | #14 |
Dostradamas it is made of 22G 304 stainless. Pita. I made it 22G to keep the weight down. It is extremely durable in its current formdue to the small surface area of the flat areas. And there are tons of companies making aluminum panels for these trucks that are just as susceptible to denting and it doesnt bother most ppl. Seems a bit nit picking to me.....just sayin. |
02-28-2013, 08:50 PM | #15 | |
| Re: LGFAB Skid Plate! Bolt on! Quote:
P.S. My name is "Pita" by the way. | |
02-28-2013, 08:59 PM | #16 |
haha Pita i just thought about that... I dont think you are an ahole BTW. I have one on my personal rig and It has held up to some serious stuff... Plus lets be realistic.. when you fall that hard, you never land on the piece you bought to protect your truck.. it is always the 150 set of beadlocks or the vanquish $60 links that take the destruction. hahaha. I have yet to dent mine but I will seriously consider thickening it up on the next batch.. if feedback says it should be...
02-28-2013, 11:33 PM | #17 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
looks like it would help slide over rocks
03-01-2013, 01:33 PM | #18 |
In my 20 years selling industrial pipe, valve, & fittings, 304 SS will rust if subjected to a wet environment. Generally you need a 316 or higher to avoid rust from just atmospheric water.
03-01-2013, 01:52 PM | #19 |
LGFab, I think some folks might be a bit confused about this being a "replacement" skid. This skid looks like it simply bolts on the outside of the existing skid. Any contact with the rocks will simply smash this skid into the existing skid plate and should result in no deformation... I like it! Nice work! I used to build links on my comp trucks out of SS for the same reasons you built this skid out of this material....it wont easily gouge and slides well. |
03-01-2013, 07:02 PM | #20 |
Thanks Jeremy! It is a Bolt on. Not a replacement. I can say that I have not seen a bit of rust on any 304 piece I have had made.
LGFAB Skid Plate! Bolt on! - Similar Threads | ||||
Measurements for stock AX10 Transmission mounting plate/skid plate | Apoch | Axial AX-10 Scorpion | 5 | 04-09-2012 07:53 AM |
Skid Plate | msd44 | Axial AX-10 Scorpion | 12 | 03-29-2010 10:49 PM |
Skid plate | Olli23 | Venom Creeper | 4 | 02-06-2009 04:45 AM |
skid plate | jose77 | HPI Wheely King | 8 | 05-31-2008 03:54 PM |
