03-03-2013, 01:30 PM | #1 |
Newbie Join Date: Jul 2011 Location: Cottonwood Heights
| Wraith battery
I have a wraith with a tekin 35t motor, would a 30c 3s 2700mah battery work?
03-03-2013, 01:48 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Wraith battery
If that is a stock ESC.....AE-2 then no you can't use 3S. 2S max!
03-03-2013, 01:51 PM | #3 |
Rock Stacker Join Date: May 2012 Location: Kelso
| Re: Wraith battery
You can run 3s on the stock ae-2 with a castle bec
03-03-2013, 01:53 PM | #4 |
| Re: Wraith battery
What if I don't have a BEC?
03-03-2013, 02:26 PM | #5 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: Wraith battery |
03-03-2013, 02:34 PM | #6 |
| Re: Wraith battery
Whoa totally didn't even see his post. Thanks. That's what I thought
03-04-2013, 06:00 AM | #7 |
Rock Stacker Join Date: Jan 2013 Location: Kentucky
| Re: Wraith battery
So just the bec for the servo or the bec for the esc?
03-04-2013, 06:39 AM | #8 |
| Re: Wraith battery
i ran 3s with the sv2 controller and no external bec with no problems. id say it depends on your servo setup. if stock youl mostly likly have no issues if you have power hungry 7950 you might brown out from what i understand the ae-2 is the sv2 with a few less programming features. |
03-04-2013, 09:23 AM | #9 |
| Re: Wraith battery
If you don't run the AE-2 with an external BEC you'll most likely fry it. I installed a BEC on mineand ran it on 3s for months before I sold it. For the cost of a BEC ($20) I wouldn't chance smoking your esc.
03-24-2013, 01:02 PM | #10 |
| Re: Wraith battery
Where do you plug in a BEC on a stock wraith?
03-24-2013, 01:44 PM | #11 |
Pebble Pounder Join Date: Apr 2012 Location: Bellingham
Good to know. I was wondering why my wraith was acting funny (glitchy) when I put in a 3s lipo Running stock ae2 with as3 servo. So a external bec should solve the problem. |
03-24-2013, 01:46 PM | #12 |
Newbie Join Date: Oct 2012 Location: Colo. USA,Earth.
| Re: Wraith battery
there are some good you tube videos on how to install a bec
03-24-2013, 02:09 PM | #13 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
03-24-2013, 06:55 PM | #14 |
| Re: Wraith battery
You are supposed to plug the BEC into the battery port but on a stock wraith the lights are plugged into the battery port. What do I do?
03-24-2013, 06:56 PM | #15 |
| Re: Wraith battery
What's a good voltage to set a BEC to on a wraith?
03-24-2013, 07:02 PM | #16 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
| Re: Wraith battery
6 volts for a minimum. That's what my is at.
03-24-2013, 07:20 PM | #17 |
| Re: Wraith battery
It should work on any open reciever spot
03-25-2013, 11:25 AM | #18 |
| Re: Wraith battery
Or just plug the bec and lights into a Y harness and plug them inti the battery slot I have the rx.
03-25-2013, 12:31 PM | #19 |
Wraith battery - Similar Threads | ||||
Best Battery for Wraith | hamalmarzooqi | Axial Wraith | 12 | 03-04-2014 06:41 PM |
Wraith battery | Bayouboy840 | Electronics | 5 | 01-18-2013 11:20 AM |
Battery for my Wraith | Steve Hipsley | Axial Wraith | 1 | 02-26-2012 02:18 PM |
What battery connector does the Wraith use? | strap624 | Axial Wraith | 9 | 09-15-2011 11:48 AM |
