03-06-2013, 10:05 PM | #1 |
Pebble Pounder Join Date: Jul 2007 Location: Phoenix
| My kit build
My friend Adam (AZWheelman)wanted to see the changes I made to my Wraith, so I'm posting it up. This was a Kit build. HiTec 7954SG servo Sidewinder SV2 ESC Tekin 45 turn handwound Hyperion 2500 mah 3S battery This first pic I wanted to show the ride height after I flipped the rear brace, and moved the front shocks back one hole. I put the Chisels and Proline wheels off my Wheely King. Here I'm showing my steering setup. Stold the idea from ****'s Suicide switch setup. Just found some turnbuckles in my pile of crap. ...and then some poser shots |
03-06-2013, 10:16 PM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: avondale
| Re: My kit build
Nice job !!!! Lookn good time to get it dirty !!!!
03-07-2013, 01:48 AM | #3 |
| Re: My kit build
The suicide steering set up is all screwy. Unless you made changes and made both steering links the same length it will never really work right. Other than that the rig looks pretty sweet.
03-07-2013, 07:06 AM | #4 |
| Re: My kit build Can you elaborate on, "all screwy"? I'm curious if I'm missing something because it seems to be working fine for me. It did initially have more travel in one direction than the other, but I dialed that out with the endpoint adjustments on my Tx.
03-07-2013, 07:12 AM | #5 |
| Re: My kit build
With 2 steering arms of different lengths like the Suicide steering has, you'll get 1 tire to turn more than the other. There is nothing that EPA can do to fix that. Plus the way it's set up with no tie rod puts 2x the stress on the servo and servo horn.
03-07-2013, 08:31 AM | #6 |
| Re: My kit build Alright, I can see now the outside tire does turn more than the inside. That's no bueno, but it is a significant improvement over the plastic links in actual performance, so I guess I'm stuck with it until I can scrape up some money for a proper link.
03-07-2013, 08:36 AM | #7 |
| Re: My kit build
Yeah you can get a really nice Ti set up for about $30, but it'll do in the mean time. Just make sure the tire that turns further isn't causing the axle shaft to bind. Cause if it does you'll break something
03-07-2013, 10:05 AM | #8 |
| Re: My kit build
Sounds like some good old test in tune time ..we need to do a shake down run soon !!
03-07-2013, 07:59 PM | #9 |
| Re: My kit build
the servo horn isnt quite centerd i dont think so no matter what itl steer alittle more one way. if thats a hitech 7950 and metal arm im sure it cand handle it and then some. right guys isnt it like tuffer then rocks we crawl on |
03-07-2013, 08:24 PM | #10 |
| Re: My kit build
Its dosent have tobe perfectly centered just close,,, a little off like the owner its ok lol! And its got 7954 @7.4v thats like 400oz not bad !!
03-07-2013, 08:26 PM | #11 |
| Re: My kit build
yup thats what i was getting at. my wraith doesnt steer the same both ways im alittle off so im fine if its alittle off
03-08-2013, 08:35 AM | #12 |
| Re: My kit build
I wasn't worried about the servo handling it, 404 oz-in on 7.4v, and I cranked the voltage up on the Castle BEC, but I am bothered by the inside wheel losing the steering radius. Regardless, it was working really good on my pile of rocks in my backyard. Not sure what I'm gonna do now...
03-08-2013, 09:33 AM | #13 | |
| Re: My kit build Quote:
03-10-2013, 01:04 PM | #14 |
| Re: My kit build
Those chisles hooked up good !! way better than my ripsaws ,,,last nite even did good on the dirt hill
03-14-2013, 03:18 PM | #15 |
Newbie Join Date: Jan 2013 Location: central phx
| Re: My kit build
truck looks great cant wait ill we go out and run them i picked one up yesterday
03-14-2013, 07:53 PM | #16 |
| Re: My kit build
Hopfuly sunday morning
My kit build - Similar Threads | ||||
Kit build help. | Sneakretly | Axial Wraith | 3 | 02-24-2012 10:47 AM |
Kit or Build? | Retarius | Axial SCX-10 | 5 | 08-05-2009 01:37 PM |
1.9 scale build options - Hilux kit, RC4WD kit, or piece together my own? | Nova's Ark | General Scale Talk | 8 | 06-12-2008 10:24 AM |
Axial AX-10 Scorpion 1/10 Rock Crawler Kit Build, Chapter 2 "The Mod Build" | JAM MaxAmps.com | Axial AX-10 Scorpion | 42 | 06-06-2008 10:00 PM |
AX10 RTR or Kit for a build? Kit seems more popular, but RTR has some nice features. | nukexbi | Axial AX-10 Scorpion | 21 | 05-09-2008 01:27 PM |
