03-16-2013, 06:34 AM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Problem with vp steering links
I installed my new vp steering links and at full turn my wheel drags on the rod end so hard it locks up the wheel. I have axial bead locks. Any body else have this problem?
03-16-2013, 10:00 AM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
| Re: Problem with vp steering links |
03-16-2013, 11:07 AM | #3 |
Rock Stacker Join Date: Mar 2010 Location: Wilton
I am having the same problem. What I found was the axle shaft try to pop out. Not sure how to fix it yet
03-17-2013, 01:02 PM | #4 |
Please post some pics. Sounds like something is flipped over.
03-17-2013, 01:04 PM | #5 |
03-17-2013, 01:06 PM | #6 |
03-17-2013, 02:24 PM | #7 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
You need a wider hex!! I have similar wheels. I got some wider hexes from a vendor on here and then I dremeled out the back of the rims a little. Mine still rubs a little but I am going to let friction do its job now....at least it doesn't bind up and act as a brake like it did with no mods. |
03-17-2013, 02:27 PM | #8 |
what vender did you get them from?
03-17-2013, 02:31 PM | #9 |
I forget but they were custom made. I have read guys using Traxxas ones TRA3654..
03-17-2013, 02:56 PM | #10 |
Those didn't work... If you or anybody knows where I can fid some .30 or .50 spacers let me know please
03-17-2013, 03:05 PM | #11 |
Rock Crawler Join Date: Jul 2005 Location: MD
I have the same set up as well. This is the best fix beyond the wider hex. stock xr10 wheel mod /vp hubs Gives you a lot more options. |
03-17-2013, 03:10 PM | #12 |
Actually it was J-FAB NOR-CAL that made mine. They are about 11.3mm wide total...stocks are like 8mm or 9mm. I forget. It sucks the manufacturers only give the 12mm size and not the over all width for wheel spacing. Might want to PM him and ask if he still makes any. http://www.rccrawler.com/forum/membe...-cal-49399.htm Last edited by ZippoMan; 03-17-2013 at 03:14 PM. |
03-17-2013, 03:24 PM | #13 |
Here is a picture of the ones J-Fab made. They are great quality aluminum. |
03-17-2013, 03:32 PM | #14 |
That's exactly what I need! Another question for you... What would make my motor get super hot when I crawl for like 15 minutes straight?
03-17-2013, 08:12 PM | #15 |
What kind of motor are you running? ESC? Not sure why it gets super hot.
03-17-2013, 09:14 PM | #16 |
| Re: Problem with vp steering links My RTR Wraith Stock 20T Motor and Stock ESC would get so hot that you could smell the ESC emitting that wonderful hot electronics smell. Then I swapped out my Spur for an 87T and my Pinion with a 14T and all that stopped. This delivers a lot more torque to make it easier to turn those tires when more power is needed during crawling. This is what worked for me.
03-17-2013, 09:25 PM | #17 |
Newbie Join Date: Oct 2012 Location: Ossian
I'm running the exact same rims with all VP parts. You need to get some wider hexes. I ended up getting some Top Cad parts from Asia Tees.
03-17-2013, 10:01 PM | #18 | |
| Re: Problem with vp steering links Quote:
The ones I got from J-Fab are slightly too narrow still but work once the rims are sanded with a dremel. If J-Fab would have made them about 1mm wider.....AHHHHHHH Last edited by ZippoMan; 03-17-2013 at 10:14 PM. | |
03-17-2013, 10:44 PM | #19 |
35 turn integy and stock esc.
03-17-2013, 11:07 PM | #20 |
It must be the gearing, I wonder about your pinion and spur? Maybe lack of air flow around motor? Not sure.
Problem with vp steering links - Similar Threads | ||||
Steering Problem | alexchen86 | 2.2 Scale Rigs | 8 | 01-13-2012 11:03 AM |
SCX 10, Steering problem... more steering one way than the other? | C_Money | Axial SCX-10 | 7 | 12-28-2009 04:54 PM |
steering problem.... steering is stuck all the way right | lukem80 | General Crawlers | 10 | 12-14-2006 11:30 AM |
Steering problem | AFJ | Tamiya Txt-1 and Juggernaut | 3 | 07-26-2004 10:57 AM |
