03-21-2013, 04:19 PM | #1 |
Newbie Join Date: Aug 2012 Location: In a van down by the river
| RTR esc doesnt beep...
CHanged my motor out to an axial 55t and now the esc doesnt beep when I turn it on like it did before the motor swap. Sometimes when I turn it on just the steering will work and no throttle. Wraith has seen ZERO water, just dry grass and a wood pile in my backyard. Is the esc bad? Loose connection? |
03-21-2013, 04:23 PM | #2 |
Newbie Join Date: Oct 2012 Location: Colo. USA,Earth.
| Re: RTR esc doesnt beep...
check the connection at the motor.the esc doesnt beep when the motor is not connected
03-21-2013, 05:15 PM | #3 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
If only steering works you are plugged into the wrong port.
03-21-2013, 06:25 PM | #4 |
Rock Stacker Join Date: Feb 2013 Location: lawerenceville
Check motor connect mske sure pluggef into esc correctly i had same issue
03-21-2013, 09:34 PM | #5 |
Only connections I undid were the two going to the motor. I can turn it on and the truck will work fine but not beep. Sometimes the throttle will stop working as I'm playing with it. Guess I have to pull it apart....
03-22-2013, 02:31 PM | #6 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
The beep noise is actually created by the motor. No noise means either the connection to the motor is bad or the motor itself has problems. You can connect the old motor without mounting it to see if the esc is still functioning.
RTR esc doesnt beep... - Similar Threads | ||||
[HOMELESS] HOBBIES HOT[MOG] 1.9 UniMog Build☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆☆BEEP BEEP MUTHRMOGR | ScaleDustin | 1.9 Scale Rigs | 55 | 02-22-2013 12:56 PM |
Why would my motor beep? | duleonar | HPI Wheely King | 3 | 10-26-2007 05:03 PM |
Beep Beep 53 | DARKHORSE | Paint and Body | 26 | 05-03-2007 04:38 PM |
