03-22-2013, 05:46 AM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: Long Island
| Robinson Racing Gen3 Slipper Unit
I bought the Robinson Racing Gen3 Slipper Unit w/80T Steel Spur Gear [RRP1545] and for one the spacer was bent (Grrrr) and would not slide down the shaft to replace the stock spacer, two, two, NO Pin was included to replace the stock one. When I installed it with the stock pin it was able to rub is that normal, the Stock setup has no shot to rub, did I use the wrong Slipper from Robinson Racing or if I had the right pin and spacer it would be fine? Thanks |
03-22-2013, 06:09 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Re: Robinson Racing Gen3 Slipper Unit
IMO RR is waaaay overated and quality is going down hill!!! A member of my club has a full RR tranny and has broke everything from the slipper to the output shaft on the lower gear (multiple times) while my HR steel gears and Axial slipper and outputs have held together no problems... Both running Pro4 3300's... |
03-22-2013, 06:18 AM | #3 | |
| Re: Robinson Racing Gen3 Slipper Unit Quote:
I put the stock back on, would you just stay stock for the slipper then ? | |
03-22-2013, 06:36 AM | #4 | |
I used the #7856 Robinson Racing Steel Slipper with the SuperShafty WRAITH & AX-10 BEEFY Top Shaft. WRAITH & AX-10 BEEFY Top Shaft - Super Shafty No problems with at all and you get 32P gears. | |
03-22-2013, 06:59 AM | #5 |
| Re: Robinson Racing Gen3 Slipper Unit I do run the Axial slipper with 32p plastic spur and no plans on ever changing it... The only thing I have done to it is scar a waffle pattern in the slipper material and added a little loctight...
03-22-2013, 07:17 AM | #6 | |
So you would change the top shaft ? U have a pic of your slipper and shaft. Does the slipper pin from rrp really help. I felt like the gear would rub on the mount easily. | |
03-22-2013, 07:33 AM | #7 | |
I will try to post pictures when I get home from work. | |
03-22-2013, 07:39 AM | #8 | |
if U can get pics, that would be great, maybe I'll just send this back and get the SLash slipper from RRP if that's gonna work? | |
03-22-2013, 07:58 PM | #9 | |
Here is a picture of the BEEFY Top Shaft on the Left and stock top shaft on the right. As you can see the BEEFY Top Shaft is longer to accommodate the slipper clutch. I have no issues with this setup rubbing. ThBEEFY Top Shaft kit + the #7856 slipper clutch contain all of the parts for the installation. | |
03-22-2013, 09:24 PM | #10 | |
cool, the motor plate fits well to? | |
03-22-2013, 09:26 PM | #11 |
| Re: Robinson Racing Gen3 Slipper Unit Wow you see it here, thanks a bunch |
03-22-2013, 10:04 PM | #12 |
Pebble Pounder Join Date: Nov 2011 Location: Oregon City
I still like there stuff but I bought a pinion the other day and the set screw hole wasn't tapped!
03-22-2013, 10:11 PM | #13 |
| Re: Robinson Racing Gen3 Slipper Unit |
03-22-2013, 10:22 PM | #14 |
| Re: Robinson Racing Gen3 Slipper Unit In case you didn't know about it, there is a give away going on for the ultimate motor plate in http://www.rccrawler.com/forum/gener...pur-guard.html |
03-22-2013, 11:13 PM | #15 | |
Thank You! | |
03-26-2013, 04:03 PM | #16 |
Robinson Racing did get back to me and they are sending me a NEW spacer to replace the bent one that came in the package..
03-27-2013, 09:16 PM | #17 |
Newbie Join Date: Apr 2012 Location: Newbern TN
I'm not impressed with my slipper clutch. I have mine spring almost bottomed out and my rig still couldn't start up the wall with out it slipping. Have I done something wrong?
05-13-2014, 08:42 PM | #18 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
I just installed the gen 3 80t slipper unit and cranked the spring down as much as I could and it will not hold. The traxxas brushless motor just smokes it. Im running 3s. I had a roc 412 3100kv on 4s and never had an issue. What gives? Not to happy I spent 47.00 plus tax for junk
06-19-2014, 06:11 PM | #19 |
Newbie Join Date: Mar 2014 Location: salem
| Re: Robinson Racing Gen3 Slipper Unit same thing with my honcho it slipping so I add some washer it work like charms also I broken rear shaft lol my next is get steel rear shaft.
Robinson Racing Gen3 Slipper Unit - Similar Threads | ||||
Robinson slipper 56T Gen3 Slash | sixhundred71 | Axial Wraith | 2 | 03-25-2015 07:38 AM |
Converting To a Robinson Racing Slipper Clutch | tractionaction | Axial SCX-10 | 0 | 06-15-2012 03:56 AM |
robinson racing slipper 48p | kmas | Axial Wraith | 3 | 05-11-2012 10:08 PM |
Robinson Racing Wraith Slipper unit & gears IN STOCK | RPP Hobby | RPP Hobby | 0 | 01-13-2012 09:27 PM |
