06-02-2019, 11:29 AM | #1 |
I wanna be Dave Join Date: Sep 2004
| wraith 1.9 chassis fix?
Has anyone come up with a solution for a broken front frame rail other then replacing it with a new one and then using one of the preventative measures out on the market. My chassis rail is broken and it would be cool if there was something out there to buy that would fix the broken piece. i have no front bumper now due to the broken chassis rail. I will prolly just get replacements as i doubt there is anything out there like this but ya never know.. Thanks |
06-04-2019, 08:31 AM | #2 |
Newbie Join Date: Jun 2019 Location: reedley ca
| Re: wraith 1.9 chassis fix?
I just broke my frame just behind the bumper also. I just bought it and took it in my front yard and crawled for 20 minutes and bam broke. Not happy and replacement rails are on backorder. Not COOL
06-04-2019, 09:14 AM | #3 |
i broke my og wraith cage so many times and at the time i broke the last set of rails they dident have anymore parts in stock so i went with the steel cage that was the start of my unsatisfaction with axial also why i started building my own rigs from scratch that cage alone disqualified me from running my wraith at axial fest so i stoped going i feel axial is leting its customers down by relesing junk that we all know is easy to fix from the factory that broken frame should be warrented being its a manufactures defect they should just give you a new one if they dont have replacement parts available i would raise hell with axial then horizon till the problem is fixed Last edited by ferp420; 06-04-2019 at 09:16 AM. |
06-04-2019, 12:57 PM | #4 |
RCC Addict Join Date: Oct 2014 Location: UK
The SSD chassis fix is ready and will be shipping to Amain this week. The product page is not up yet but will be next week.
06-04-2019, 01:02 PM | #5 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
| Re: wraith 1.9 chassis fix? |
06-07-2019, 11:09 AM | #6 |
06-07-2019, 03:05 PM | #7 |
06-08-2019, 08:32 AM | #8 |
08-19-2019, 01:33 PM | #9 |
Newbie Join Date: Jul 2010 Location: Idaho
So I broke my 1.9 Wraith frame (probably do to a 5’ accidental fall off a retaining wall), this was at the rear tube frame rail on the passenger side. This happened about a week before attending Axialfest 19’ and although I put in a warranty claim with Horizon the frame kit was on back order status. To remedy this issue I drilled two small holes in the broken frame tubes and used black thin gage wire to tie the broken section back together. Since then the back ordered frame kit showed up a couple of days ago, long after Axialfest was over. It was interesting to see that this kit included the new revision of the beefed up front end section, looks like they have strengthened the front end tubes by adding extra gusset of molded plastic close to where the screw hole in the lower front tube fastens to the shock tower. I will hold off on using these parts for now as my repair is still holding strong! I’d use this repair in the field too, keep it in mind for you Wraith owners! Sent from my iPad using Tapatalk Last edited by Howlkat; 08-19-2019 at 01:38 PM. |
08-24-2019, 10:12 AM | #10 |
i see you went full BGR on your wraith too. I just got done adding all my stuff.
08-29-2019, 10:56 PM | #11 | |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: wraith 1.9 chassis fix? Quote:
08-30-2019, 11:53 AM | #12 |
Pebble Pounder Join Date: Jan 2010 Location: CA
wraith 1.9 chassis fix? - Similar Threads | ||||
Wraith hr links junk any fix for them? | sanny632 | Axial Wraith | 10 | 02-07-2014 08:54 PM |
How do you fix Wild Willy into your Wraith? | Badboy_207 | Axial Wraith | 8 | 06-30-2012 05:42 PM |
Chassis tip/lean/sideways. How to fix? | RcBro | Traxxas Crawlers | 9 | 07-09-2006 11:11 PM |
How do i fix my broken chassis? | Dana44 | General Crawlers | 10 | 04-21-2006 12:59 AM |
