03-30-2013, 12:47 PM | #1 |
Rock Stacker Join Date: Jul 2012 Location: Owasso
| wraith issues
This wraith is new out of the box, it's my buddies he left with me to solder on a deans. I went thru a couple issues getting it to even move at all, I was trying to use a nimh battery, but switched to 2s 4400mah lipo and the issue seemed to be gone. It was just jerking, with little throttle responce with the servo working. I researched the issue & it seemed to be the lipo cutoff. It responded all the way to full throttle, drove it up & down the hall. I took it outside to the driveway & got about 20ft when it came to a stop. Now it spins the motor but wont spin the wheels at all. I have no manual here, my buddy is super green to rc so I have been trying to solve this, but I am a newbie too, only have a few months of rc experience. Any ideas short of taking it back? |
03-30-2013, 01:12 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: wraith issues
Did you check the spur and pinion gears?
03-30-2013, 01:23 PM | #3 |
| Re: wraith issues
No, is there known out of the box issues? Would they just be loose? Sorry if it sounds like a dumb? But as stated above I have no manual, at least not until tomorrow when he comes out. |
03-30-2013, 01:51 PM | #4 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: wraith issues |
03-30-2013, 01:53 PM | #5 |
| Re: wraith issues
Motor spins? Do you get full throttle just sitting there? Yeah it sounds like a loose pinion on the motor or meshing issues with pinion and spur. It could even be a super loose slipper clutch.
03-30-2013, 01:58 PM | #6 |
| Re: wraith issues
Yes the motor spins all the way to full throttle. Thank you for the links |
03-30-2013, 03:03 PM | #7 |
| Re: wraith issues
Ok, I see that the drive shafts start to spin at the very start of the throttle pull, but as the motor spools up they stop spinning. This is while holding it off the ground. Would this be the slipper clutch? If so it looks like a 4mm nut on the drawing, is this used to tighten the slipper? It looks like the best way to access this is to remove the bolts that line the side of the skid plate & remove the shocks (maybe not the shocks?) |
03-30-2013, 03:12 PM | #8 |
Quarry Creeper Join Date: Jan 2013 Location: Spokane
| Re: wraith issues
Yeah just drop the skid plate take the cover off the slipper and crank it all the way down then back it off a quarter th half a turn
03-30-2013, 03:24 PM | #9 |
| Re: wraith issues
Sweet, thank you
03-30-2013, 06:26 PM | #10 |
| Re: wraith issues
Or if you are like me I just crank the slipper nut super tight and don't worry about slippy grippy!! I will tear the spur apart I am sure but I have a strong setup...with the HR aluminum trans case, RR one piece bottom gear set, RR idler and stock metal drive gear. I use 32P spur and pinion with a brushless Tekin Redline 13.5T motor. I have MIP drive shafts and this thing is smooth as butter!! Great combo in my opinion. "It's Only Money" my adopted motto!! Hehehe
03-30-2013, 06:35 PM | #11 |
| Re: wraith issues
I feel ya! I figured for a bone stock wraith a quarter turn back would be safe! I run mine as tight as it will go but I am far from stock also!
wraith issues - Similar Threads | ||||
Wraith receiver/ esc/ bec issues? Please help | Cechini | Axial Wraith | 6 | 01-31-2013 02:03 PM |
Wraith electrical issues. | OhioSuperSport | Electronics | 4 | 03-11-2012 07:59 PM |
Wraith is glitching? Accelerate/reverse issues | Elliott000 | Electronics | 8 | 07-17-2011 05:04 PM |
