04-22-2013, 04:03 PM | #1 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
| CC BEC Wraith Wiring Question
So I have my BEC hooked up and when I plug in the battery power comes on to only my Steering Servo...no power to the ESC. I have to turn on the ESC's Power switch to get power to the ESC. I thought after hooking up the BEC the power switch would no longer work. I have a servo extension in place that I trimmed the red wired out of so no power comes into it. Is this normal? Everything still works fine, I just thought the power switch would no longer be needed.... |
04-22-2013, 04:39 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: CC BEC Wraith Wiring Question
Yes the on/off switch will still work unless you cut it off and solder the + and - together. The CC BEC is powering your receiver which will then power the ESC and Steering servo plus however many other channels you have. Well that is how I have my CC BEC wired....some use it just for their servos and it is wired a little differently. Last edited by ZippoMan; 04-22-2013 at 04:42 PM. |
04-22-2013, 05:04 PM | #3 | |
| Re: CC BEC Wraith Wiring Question Quote:
Is there any benefit to just running the BEC to just the servo? | |
04-22-2013, 05:45 PM | #4 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
I think dont think there are advantages really...but i think it is good to have the option. I have been running a 120 dollar high torque servo at 7.2v through the reciever. I am going back to the 6v low amp esc bec to run the reciever and dedicating the external bec to run a 18 dollar high torque servo at 8.5v to get the best out of it.
04-23-2013, 11:27 AM | #5 |
In all my rigs I cut the switch out! I open the ESC and solder a piece of wire across the switch wires. I have OCD so for me I hate having loose wires from the switch dangling even if they are soldered together.
CC BEC Wraith Wiring Question - Similar Threads | ||||
Wiring BEC Question | doc.hamilton | Electronics | 6 | 02-14-2013 01:20 PM |
Castle BEC wiring question | Full_Throttle | Electronics | 9 | 12-26-2011 07:37 AM |
CC BEC wiring question... | shelljeep | Newbie General | 3 | 01-21-2011 09:06 AM |
Quick BEC wiring question | AdverseCity | Electronics | 4 | 09-11-2010 02:07 PM |
Newbie CC BEC wiring question | new2it | Newbie General | 7 | 04-02-2010 03:25 PM |
