![]() | #1 |
Quarry Creeper Join Date: Jul 2011 Location: Sullivan
I got my wraith running last weekend finally and got to run it on te rocks a little. question I have is on the Robinson racing 32p slipper. when running this thing i tightened it all the way down cause it was slipping with any little bind the wraith got in and wouldn't crawl for a dang. so got it right and now if it gets in a bind I'm getting a little smoking from under there. I'm assuming that its the slipper burning but may be motor not sure now that I really think about it. but I'm assuming that you all do run the slipper pad in the assy correct?
![]() | #2 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
I don't think it's the robinson slipper. It shouldn't be smoking, i'd bet that's your motor from putting so much stress on it
![]() | #3 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
OP, what motor are you running? I have run mine tight then back it out a 1/2-3/4 of a turn, I haven't noticed any slipping. That is with the Tekin ROC412 3100 on 3S.
![]() | #4 |
the motor that is in there is a no name of somekind I got used on here was supposed to be a 35t motor ill check it out this weekend got a Holmes 55t handwound I can put in it next |
![]() | #5 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Doubt it's the slipper. I run the 48p unit and have it cranked all the way down too. I run a pro4 with it and no problems. You want to close to a 5.0 gear ratio or higher with most brushed motors.
![]() | #6 |
gear wise I'm running 56t spur and 11t pinion maybe I need to drop my pinion to a 10t? |
![]() | #7 |
You can always do the finger thermometer test on the motor. If you can't hold your finger on the motor for a few seconds gear down. Seems like the damage maybe done already if it has gotten hot enough to smoke.
![]() | #8 |
yea I'm pretty sure I smoked it but oh we'll was just a cheapo motor guess ill put my other one in it till I can get another one just a newb trying to figure all this stuff out....I'm clouding how to drive lol |
![]() | #9 |
I'm running the 56t Gen3 with a 12t pinion, that spur has some weight to it, so with a sub-par motor it's going to need to work harder to get everything moving. I'd vote a fresh motor and a pinion swap, also get you one of those small infrared thermometers. That way you'll know what temp it's running.
Robinson Racing Gen3 Slipper Unit | cmnyj28 | Axial Wraith | 18 | 06-19-2014 07:11 PM |
Robinson Racing steel slipper spur rubbing | t3yf5g | Axial Wraith | 12 | 08-04-2012 09:37 PM |
Converting To a Robinson Racing Slipper Clutch | tractionaction | Axial SCX-10 | 0 | 06-15-2012 04:56 AM |
robinson racing slipper 48p | kmas | Axial Wraith | 3 | 05-11-2012 11:08 PM |
Robinson Racing Wraith Slipper unit & gears IN STOCK | RPP Hobby | RPP Hobby | 0 | 01-13-2012 10:27 PM |
