07-05-2013, 09:27 PM | #1 |
Newbie Join Date: Jun 2013 Location: Cape cod
| Tranny gears and super shafty top shaft
Hi all, which steel gear set do I use if I plan on using the super shafty top shaft when it is restocked. I am following harleys guide. One thing I was confused about with the gears, is the robison only shows two gears for sale and hot racing shows three. which set do I buy, and which top gear will fit on super shafty? Thanks all |
07-05-2013, 09:44 PM | #2 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
| Re: Tranny gears and super shafty top shaft
I bought the hot racing gears and they will fit on the super shafty. The robinson racing gears will also fit. I've had no problems with my HR gears. Been running them for about a month.
07-05-2013, 09:49 PM | #3 |
Awesome thanks! I didnt see a top shaft gear sold by robinson racing, only final drive gear and idler.
07-05-2013, 10:27 PM | #4 |
I think they do but i'm not 100% sure. Never looked into it because I bought the HR gears. are you going to a bl system? Is that why you are upgrading?
07-05-2013, 10:53 PM | #5 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
RRP does not make a top gear at this time, probably never will. I have purchased many sets of the HR gears, I use all 3 when I install them. The SuperShafty top shaft is the same diameter as the stock one, it is just longer and tougher than the stock one.
07-06-2013, 05:46 AM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I just did the supershafty trans but it had the stock top gear and rrp idler cause they didnt have anymore sets of the HR gears, one full pack then 50' of a new pack and the top gear let go! Took out the idler and very slight damage to the HR lower gear. The stock gear and rrp gears seem like a hardend pot metal, while the HR gears are a true steel and wont chip or crack. So i say only HR gears!
07-06-2013, 12:35 PM | #7 |
You will need to look at the transmission case to make sure it didn't warped and check the bearings to see if they are ok. A warped case or bad bearings could damage even a new HR gear set. I switched to the Vanquish transmission case due to the plastic case warping and cracking. |
07-07-2013, 10:28 AM | #8 |
Yes I am going brushless, and thanks for all the replys.
Tranny gears and super shafty top shaft - Similar Threads | ||||
Super Shafty Top Shaft drive gear | ik632 | Axial Wraith | 14 | 08-23-2012 08:41 PM |
Tranny for super shafty? | BeeRC | Superclass Crawlers | 12 | 11-13-2009 09:04 PM |
pede tranny top shaft? | Xtant3150c | Newbie General | 5 | 05-30-2006 01:38 PM |
