Thread: Wraith tranny mirroring?
Old 08-23-2013, 02:44 PM   #1
Default Wraith tranny mirroring?
Use to do this with the scx10 but can it also be done with the wraith? Thinking I may have to get the scx10 tranny case to do so.
Reason I ask is due to all the torque twist off the line.
Any ideas?
juttsvw is offline   Reply With Quote
Old 08-23-2013, 05:06 PM   #2
Default Re: Wraith tranny mirroring?
Does anyone know?
Old 08-23-2013, 05:19 PM   #3
Mirror Imaged Transmission
Not Wraith specific but those trannys are very similar.
Dostradamas is offline   Reply With Quote
Old 08-23-2013, 06:01 PM   #4
Natedog's Avatar
Any ideas?
No, cannot mirror with stock tranny case. Different shock oil and springs will help torque twist as will a rear swaybar.
An AX/SCX tranny could be used and mirrored though.
Old 08-23-2013, 07:55 PM   #5
Yes I could just use different shock oil but I was trying to fix the problem all together. But the real problem is the wraith tranny case has the dig option in the way. Plus in the end you won't be able to use your spur cover.
Oh well. Sway bars it is.
Thanks guys
Old 08-24-2013, 06:14 AM   #6
I think running the diffs the rtr way and switching the esc to reverse helps a lot with torque twist. The motor and driveshafts spin different directions. Not sure if they spin the same direction when set up like the kit cause I never looked!
Cableman is offline   Reply With Quote
Old 08-24-2013, 06:23 AM   #7
only if u put a stock scx10 transmision u cand o that.with the wraith transmision is imposible
Kitty is offline   Reply With Quote
Old 02-02-2015, 12:24 AM   #8
Leave the trans as is and just swap the spur shaft and motor plate around ?
SouthernComfort is offline   Reply With Quote
Old 02-02-2015, 01:38 AM   #9
Can't do that with the wraith trans due to the area of the case for a dig.
fr8cture is offline   Reply With Quote
Old 03-17-2016, 10:44 PM   #10
Just take the tube body off and turn it around. Then swap the power leads on the motor to get F/R right and move the knuckles to the other axle.
This will let you lay down a good size battery on the lower chassis tube after you trim or cut off the dig servo support. This will help with torque twist and lowers the center of gravity a great deal buy moving the battery to the lowest possible spot on the chassis. As well as keeping more of the weight forward of the center point of the rig.
mach2nh is offline   Reply With Quote
Old 03-19-2016, 08:04 AM   #11
TEAM MODERATOR
Reflection's Avatar
Why move the knuckles?
Reflection is offline   Reply With Quote
Old 03-19-2016, 08:56 AM   #12
He's recommending turning the cage around on the skid plate and reversing the motor rotation, it will be rear steer if the knuckles/C-hubs/steering stay on the axle that will be in the rear after the change.
Soldat Vaillant is offline   Reply With Quote
Old 03-19-2016, 09:21 PM   #13
TEAM MODERATOR
Reflection's Avatar
Well, I see it now. Guess that's what I get for trying to read stuff in the morning before putting my contacts in.
Old 03-19-2016, 10:04 PM   #14
Underdrive gears and/or ssd high ratio tranny will help with your torque twist.
84yoda is offline   Reply With Quote
Old 04-05-2016, 10:27 AM   #15
Say you can't. ? I beg to differ.
Old 04-06-2016, 08:00 AM   #16
That looks like a SCX10 trans case. Yes you can do that but with the stock wraith with the dig trans you can't.
Farabomb is offline   Reply With Quote
Old 04-06-2016, 05:03 PM   #17
That is a Wraith trans, cut the servo mount off and just reversed the skid plate. Swapped front and rear axles and ring gear so it runs forward..
So YES YOU CAN reverse it !
Old 04-07-2016, 09:34 AM   #18
Interesting, I stand corrected.
I may have to try that just for fun. I can't do it with my existing AL case but I do have the old one in the parts bin.
Old 04-07-2016, 09:38 AM   #19
I could have kept the servo mount but with my battery mounted so low and back I had to cut it off.
Wraith tranny mirroring? - Similar Threads
Whats the deal with mirroring the tranny? Famous112 Axial SCX-10 14 03-30-2013 11:23 PM
Summit Mirror?? (Like Mirroring the axial tranny) mtnhrdgr2 Axial SCX-10 3 03-04-2011 03:24 PM
mirroring the trans scoutkrlr Axial AX-10 Scorpion 2 01-14-2011 08:59 PM
mirroring trans? pontiacfreak General Crawlers 10 01-05-2010 07:20 PM
mirroring an axial tranny 92civic Axial AX-10 Scorpion 3 07-22-2009 12:21 PM
