12-10-2013, 09:57 AM | #41 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Got Green Rubicon build(Devils Lettuce) |
12-10-2013, 10:00 AM | #42 |
12-11-2013, 07:25 PM | #43 |
12-11-2013, 07:29 PM | #44 |
12-14-2013, 12:50 PM | #45 |
Got some new foams... Got the 5.5 DW foams in the swampers... Just can't fit foams in the OMF vp wheels only the slw's??? Foam is Too wide on inner to fit 3 peice design have to use 5.25 DD foams to get mounted!! Last edited by sic1to; 12-15-2013 at 01:30 PM. |
12-14-2013, 01:03 PM | #46 |
12-15-2013, 01:04 AM | #47 |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
| Re: Got Green Rubicon build(Devils Lettuce) The 5.5 DD's will fit, but it's a PITA. The way I did it was mount the foams in the tire and place in the freezer for 10 min or so - this will help the foam from expanding too fast when attaching the front beadlock ring. I basically mounted the inner tire bead between hub side of the wheel and the inner ring and then pressed the whole front of the tire down while keeping the bead under the outer wheel by using a roll of masking or duct tape to press the tire down evenly. I stood on the tape roll while threading in the screws and then cinched them down carefully making sure the beads did not pop out. I haven't lost a bead yet! |
12-15-2013, 01:46 PM | #48 | |
| Re: Got Green Rubicon build(Devils Lettuce) Quote:
12-16-2013, 02:28 PM | #49 |
Rock Stacker Join Date: Aug 2012 Location: Roan Mountain
Good looking Wraith. |
12-16-2013, 11:36 PM | #50 |
12-16-2013, 11:42 PM | #51 |
12-20-2013, 05:42 PM | #52 |
Foam test! CI standard dueces wild with swampers. Side hill shot... Excellent sidewall with crawling ability & can turn wide open without tire wrap! The tire foam combo is working great! Getting MT claws or BFG's next to run & test against swampers on other wheels to compare both tires, same foams. I can say the swampers are doing really well taking steep grade climbs & side hill ability is very good also, we see how the tire I choose does??? |
12-21-2013, 04:53 PM | #53 |
Newbie Join Date: Oct 2013 Location: Erwin tn
Man that looks good like the set up
12-21-2013, 07:03 PM | #54 |
01-27-2014, 04:07 PM | #55 |
Couple poser & action shots... A lil air!!! & while I got it tore down added some (eyeball engineering) link mounts & pan brace...Ty Duuuuuude & always Rick With SS!!! Sorry not best pic Added spacer on one side cause I'm running 3 link. Can't wait to test these out, read & heard good reviews. Needed no interior mods & perfect pinion angle(not shown) in top mounting holes!!! |
02-08-2014, 08:54 AM | #56 |
| Re: Got Green Rubicon build(Devils Lettuce) Last edited by sic1to; 02-16-2014 at 06:11 PM. |
02-16-2014, 06:19 PM | #57 |
02-16-2014, 06:28 PM | #58 |
Newbie Join Date: Feb 2014 Location: Roanoke
How much has this rig stuck you with?
02-16-2014, 08:20 PM | #59 |
After the test/tune-build/rebuild prob in the neighborhood of $2500??? |
02-16-2014, 08:33 PM | #60 |
This build has over a $1000 & don't include elec,front gearbox,tires/wheels.stock wraith stuff(two doors & skid)!!! Minus the min it springs??? Two sweet pieces on this ifs build will be the DMG chassis & SS Bomp proof trans!!! : It don't take long to sink a $$$ in any rig but do it right first time helps!!! This will be a new thread coming soon "BANSHEE" ifs build. |
Got Green Rubicon build(Devils Lettuce) - Similar Threads | ||||
My build... The Green Meany!!!!! | stroker613 | Axial Wraith | 10 | 09-18-2011 08:09 PM |
Green Team Build | Unlimited_Class | General Crawlers | 3 | 01-07-2009 11:32 AM |
