Thread: ifs wraith build question
Old 10-12-2013, 09:03 AM   #1
Default ifs wraith build question
before you ask i have searched!
i am looking to start collecting parts to convert my wraith to ifs using exo parts. curently im just trying to get a parts list with numbers together so i know what i need. which brings up my first question.
what exo parts do i need? from what ive seen i need the entire front end of the exo and a chassis.
my next question is what is the best/easiest way to secure the exo chassis to a wraith skid?
Sent from my iPod touch using Tapatalk
c0bra is offline   Reply With Quote
Old 10-12-2013, 10:04 AM   #2
Default Re: ifs wraith build question
There is a few threads on Axial Racing and here are some links.
Axial Racing - Project Wrexo – The Ingredients! <--- Project Wrexo - The Ingredients!
Axial Racing - Project Wrexo – Body Off Photos <--- Project Wrexo - Body Off Photos
Axial Racing - Blog <--- This is just a link to the Wraith section of the forums at Axial Racing. You might be able to find something yourself.
Can't wait to see this thing, be sure to post some pics.
lostonthetrails is offline   Reply With Quote
Old 10-12-2013, 11:29 AM   #3
Arrow Re: ifs wraith build question
Here is a list cross referenced from the RTR and Kit instruction manuals. Some part numbers may be listed twice accidentally or on purpose. You'll have to check how many comes in a package or on a parts tree to determine the exact number you will need to purchase. I did not look that up and account for exact quantities. This list will only get you the front assembly and chassis plate. There are options you can substitute but that will be options for you to choose on your own.
Front assembly and diff parts:
ax30381
axa1162
axa1230 bearing 10x15x4 (x4)
ax80002
ax30390
axa1393
ax30170
ax30385
ax30392
ax30393
ax30408
ax30163
axa1221 Bearing 5x11x4 (x2)
ax80091
ax30383
ax80093
ax80097
ax30418
ax30366
ax80106
ax30382
ax80099
axa181
axa1218 bearing 5x10x4 (x2)
ax80111
ax30174
ax80100 or (ax30811, ax30812 and ax80100)
axa1028
ax80119 or (axa1640,ax80092)
ax80018
steering unit:
ax30384
axa1210 bearing 4x7x2.5 (x4)
axa1222 bearing 6x3x2.5 (x2)
ax30801
ax80102
ax30806
ax30409
ax80119 or (axa1641 and ax80005)
ax80101
axa1635
ax80005
your choice of servo horn
chassis and bumper:
ax30798
ax80093
ax30799
shocks:
ax30147
ax80035
ax80036
axa1184
axa1202
ax30113
ax80034
axa1069
ax80033
axa1041
ax30112
ax30229 stock spring - you choose
You will need to choose a wheel that will work for your build with adjustable hubs and 12mm mounting hex hub. The EXO front end is wider than the wraith rear so you will have to offset the rear to get the same wheel track.
**this list does not include the screws or nuts except the shock nut.**
I listed the differences between the RTR and Kit when you see "*part number or (*more part numbers)"
This is just an initial wag as a preoccupied dad - I'm sure you will find mistakes
redsawacs is offline   Reply With Quote
Old 10-12-2013, 11:30 AM   #4
There are plenty threads to cover ur se one ? Most use 4 bolts all corners of the wraith skid they will mount threw the exo chassis and the wraith skid then the 4 screws that will hold the wraith trans you will have to drill holes for that as well....ur 1st ? Is a matter of google and pen and paper...the whole exo front in is used but u can piece together aftermarket parts for a few bucks more which I suggest read all the threads u can jia has a good write up with aftermarket parts list and I'm trying to do a good build thread lol
gsrcivic is offline   Reply With Quote
Old 10-12-2013, 11:31 AM   #5
I secured the chassis to the Wraith skid using 3 4mm button head screws from the inside out and screwed them into the exo chassis plate after drilling and tapping holes...truely a critical and exact procedure to keep the front end square to the frame.
Old 02-06-2014, 10:07 AM   #6
i used a blue monkey ifs kit to bolt up the exo front.
Joe_Sully is offline   Reply With Quote
Old 02-06-2014, 10:21 AM   #7
This thread was a tad older than the BM kit. The good ole days of ingenuity
Blue monkey kit is sick though. Don't have one yet as I built my ifs wraiths early last year and over engineered them
Joshs4x4toyz is offline   Reply With Quote
Old 02-13-2014, 02:28 PM   #8
Rarther over than under bmrc is a great kit
Sent from my HTC One using Tapatalk
Old 02-13-2014, 03:03 PM   #9
parts list without buying a EXO roller
this price is with all the "mack daddy" parts you can put on it & some parts are optional.
now you can save some $$ by using the stock EXO parts.
"but be warned"
big motor/battery & high speed, stock parts will not last long !!
Blue monkey IFS convershion kit - $80.00
Blue monkey Titanium front IFS link set - $30.00
AX80091 EXO bulk head - stock $9.00 - alum $44.00*
EXO front alum swing arms - $23.00
EXO front alum caster blocks - $22.00 to $32.00
EXO front alum steering knuckle - $22.00 to $33.00
TRA3743A slash alum steering bellcrank - $30.00
AX80100 front chassis guard & toe block insert set - $7.00
AXI30382 king pin set X2 - $22.00
AXI30174 outer hinge pin set - $6.00
AXI30863 alum toe block set - $12.00
AXA0128 3x61 cap screw set - $3.00
AXI80093 front bumper set - $14.00*
AX30395 HD bevel gear - $28.00
AX30782 Sway bar rear $40.00
grip fab locker - $22.00
MIP wraith drive shafts X2 - $120.00
MIP slash keyed front axle X2 - $23.00
leaves these other things;
full wraith chassis - skid - $$/??
complete trans - complete rear end & links - $$/??
Blue monkey duel lower trailing arms - $35.00*
all front end bearings - (bevel gear 2 - pinion 2 & hubs 4) - $$/??
2mm grub screws X6 - $3.00
fast eddys wraith front end shim kit x2 - $10.00
shocks - $$/??
tires/foams & wheels - $$/??
all electronics - $$/??
DmG trailing arm stiffy kit $190.00*
*optional - parts
the DMG is offline   Reply With Quote
ifs wraith build question - Similar Threads
Mad Skinz Terra-Wraith IFS Build scottanthony Axial Wraith 38 03-06-2014 01:59 PM
Szczerba's IFS Wraith Build #2 Szczerba Axial Wraith 22 01-16-2014 11:59 AM
Ifs wraith from irok question mtgrizzlymn Axial Wraith 14 11-20-2012 12:50 PM
Real-time IFS Wraith build. JasonInAugusta Axial Wraith 66 10-12-2012 01:59 AM
Wraith killer - IFS scratch build rock racer red_zook 2.2 Scale Rigs 28 05-19-2012 08:55 PM
