11-06-2013, 10:47 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Tacoma
| What KV ROC412 for a RCW4D 2 Speed Wraith?
Running ah HH HW Brushed but looking at maybe going to a MMP and Tekin ROC412. I'm running the RC4WD 2 speed wraith tranny so an unusual gear ratio.
11-07-2013, 07:08 AM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: What KV ROC412 for a RCW4D 2 Speed Wraith?
3100kv
11-07-2013, 09:09 AM | #3 |
Newbie Join Date: Aug 2013 Location: CenCal
What Specs on your Holmes motor?
11-08-2013, 03:39 PM | #4 |
27T 4mm Medium Wind (maybe heavy wind) 7mm Comm Stand up brushes I think. Works well I just wish I had more high speed in second but its a hoot.
11-08-2013, 03:53 PM | #5 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
I was in the same boat as you are, but had a HH 35T setup. Great motor with gobs of tq and super smooth for crawling, but like you, I wanted more when I shifted into high gear. I went with the pro4 3300, geared it down to 12/60 final, and it's hella fun with great power on tap anytime but still crawls well in low range. I can just clear the doubles at my local track, the look on peoples face is priceless. |
11-08-2013, 10:37 PM | #6 |
What slipper are you using. The stock rc4wd slips in second gear which seems weird to me. Why in second but not in first? Am I so low in 1st gear that its impossible? My 27T is geared 15/60. Anything less and 2nd gear just sucks. Anything higher and 1st gear is too weak for my taste.
11-09-2013, 04:13 AM | #7 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
I have the roc412 3100kv with the 2 speed. Geared 13/54 and it is alittle on the fast side. I was geared 13/60 and it would stand up on 2 wheels on asphalt and walk away from sc trucks until it was time to turn then I would wreck and they pass. There is no stability for tight turning at speed with these things but straight line and they are a rocket. I can still crawl slow in low gear also. Slipper I removed the spring added washers and tightened it all the way down.
11-09-2013, 12:16 PM | #8 | |
| Re: What KV ROC412 for a RCW4D 2 Speed Wraith? Quote:
What KV ROC412 for a RCW4D 2 Speed Wraith? - Similar Threads | ||||
2 speed wraith build | imcochrane | Axial Wraith | 5 | 02-05-2016 08:10 AM |
What KV Tekin ROC412 for crawling & wheel speed? | it8ezbngrn | Axial SCX-10 | 2 | 11-06-2013 10:58 PM |
Wraith 2 speed Spur gear | Jacksprogis | Axial Wraith | 3 | 03-24-2013 02:20 PM |
2-speed wraith | suzuki | Axial Wraith | 1 | 09-11-2011 09:21 PM |
Wraith Speed Problems!! | WarTrader | Axial Wraith | 12 | 08-29-2011 10:59 AM |
