11-08-2013, 01:43 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Hudson
| new to the Wraith world, lowering question...
I just got a Wraith and stock these things sit pretty high. I've flipped the shock mounts on the axles but it doesn't give all that much of a drop. What else should I do to get it to sit with a lower center of gravity? RIZ |
11-08-2013, 01:53 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: new to the Wraith world, lowering question...
There are many upper shock mount lowering kits out there. I don't remember who I got mine from.
11-08-2013, 01:56 PM | #3 |
RCC Addict Join Date: Aug 2013 Location: Missoula
You can flip the entire rear upper shock mount to lower it some as well |
11-08-2013, 02:00 PM | #4 |
| Re: new to the Wraith world, lowering question... |
11-08-2013, 02:04 PM | #5 |
Here is my Wraith in it's current form. My shocks are Traxxas Big Bores. I "THINK" they are the 3.5" version. Whatever the T/E-Maxx uses. I swapped out the shock rod ends for slightly shorter rod ends. Flipped the rear shock tower. The front springs are a lot softer than the rear. The front sits about mid compression on the shock for a level ride height. My axles are VP Currie so the axle shock mounts can't be flipped, but I never did that on the stock axles and had about the same ride height. I never liked how they stuck down below the axle tube slightly when flipped. |
11-08-2013, 02:44 PM | #6 |
Flip the lower axle mount to
11-08-2013, 03:59 PM | #7 |
Pebble Pounder Join Date: May 2013 Location: new zealand
I put the softest axial springs in mine and it sat down quite a lot...have a lot done new upper mounts and flipped the rear lower mount but you are right it doesn't do sweet stuff all, I changed it to change the drive line angle. shorter shocks also, scx10 are meant to have same travel but in a shorter body |
11-08-2013, 04:05 PM | #8 |
11-08-2013, 07:25 PM | #9 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
use shorter shocks 3.5 to lower the ride hight.
11-08-2013, 07:40 PM | #10 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
11-08-2013, 09:51 PM | #11 |
How heavy is that. Ripsaws look flat on both axles . Are there foams in them?
11-09-2013, 07:15 PM | #12 |
| Re: new to the Wraith world, lowering question... I never weighed it, but I guess it was about 8 lbs or so. Almost all of the weight was in the front due to all of the electronics under the hood. The Ripsaws were very soft just because they were becoming bald, they were the R35 compound and the stock Axial foams were worn out. The wheels did have a lot of weight in them from the previous owner as well.
11-09-2013, 08:13 PM | #13 |
Lol. Cool stock foams are soft They don't look that bald to me. More Luke 70% tread left |
11-10-2013, 03:30 AM | #14 |
Rock Stacker Join Date: Oct 2013 Location: Cotati, California
+1 Shorter Shocks. It also seemed to help lower mine when I replaced the stock links with vanquish links. or maybe I'm just nuts... |
11-10-2013, 10:20 AM | #15 |
Here's how mine was sitting with the lowering tricks and worked over 1/8 scale buggy rear shocks |
11-11-2013, 12:15 PM | #16 |
Pebble Pounder Join Date: Oct 2011 Location: SLC
Here is mine running losi 4" shocks with flipped lower shock mounts and flipped upper mount in the rear Sent from under there. |
12-05-2013, 05:21 PM | #18 |
Pebble Pounder Join Date: Sep 2012 Location: Rockford
Here's mine with lowering kit front and rear with pro line power strokes. |
new to the Wraith world, lowering question... - Similar Threads | ||||
wraith lowering options | skidtoy | Axial Wraith | 37 | 05-22-2013 04:58 PM |
lowering your wraith cog | kakachille | Axial Wraith | 2 | 01-25-2013 08:57 PM |
Quick wraith suspension lowering | Pateskiee | Axial Wraith | 3 | 04-14-2012 02:42 PM |
Lowering the Wraith | cyrusd | Axial Wraith | 3 | 12-12-2011 12:59 PM |
