12-22-2013, 05:05 AM | #1 |
Newbie Join Date: Dec 2013 Location: Surrey, UK
| Front wheel play
Just completed my Wraith kit. Is it normal to have "plenty" of front wheel play on the Wraith. If holding the tire/wheel top and bottom you can rock it in and out quite considerably, is this normal for the Wraith and what has people done to reduce it? Thanks Rob Sent from my GT-I9505 using Tapatalk |
12-22-2013, 05:09 AM | #2 |
Quarry Creeper Join Date: Jan 2011 Location: vincennes 2 hours south of indianapolis
| Re: Front wheel play
Shouldn't be that much slop. Mine are slightly loose cause of plastic links, but you shouldn't be able to rock the wheel back and forth
12-22-2013, 07:53 AM | #3 |
In the band for now. Join Date: Sep 2012 Location: roselle
do you have the bushings in the knuckles?
12-22-2013, 08:15 AM | #4 |
mine has slop in the bearings as all of my rc rigs do...all are RTR I have replaced bearings, tried bushings and other methods including shims to get rid of it. all of the factory bushings are installed as well. I have come to the conclusion that it is an inherent design flaw and it is not hurting a thing. I have bashed the crap out of mine and no issues of any kind... |
12-22-2013, 11:55 AM | #5 |
12-22-2013, 03:21 PM | #6 |
| Re: Front wheel play |
12-22-2013, 09:18 PM | #7 |
Front wheel play - Similar Threads | ||||
Front wheel turned inward | Madkiki | Axial Wraith | 8 | 10-22-2012 07:52 PM |
Wheel Hex Play | EXW | RC4WD Bully | 8 | 03-04-2010 08:19 PM |
Front wheel play, is this common? | Allan42 | EnRoute Berg | 15 | 05-04-2009 09:58 PM |
Front Wheel Weights....? | SeniorXJ | Tires and Wheels | 8 | 01-23-2009 04:16 AM |
Sloppy “Wheel Bearing” Play Fix | ValleyCustoms | General Crawlers | 3 | 03-10-2006 07:20 AM |
