01-05-2014, 12:35 PM | #1 |
Newbie Join Date: Apr 2013 Location: Colorado
| 32p Gear matches?
Anyone have some recommendations on what spurs will work and be the best to change to 32p? I am hoping to find something the local hobby shop might already have in stock.
01-05-2014, 01:01 PM | #2 |
| Re: 32p Gear matches?
Duratrax, associated, traxxas and kimbrough's work. If you can get to a spare spur holder, take it in with you to check fitment.
01-05-2014, 02:14 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
A 56t spur is about as big as you can get to fit....a 60t hit my MIP shaft....haven't found a 58, but I bet the cover doesn't fit with that.
01-05-2014, 02:18 PM | #4 |
Only way to get a 60t to work is delete the slipper, it'll suck in the spur closer to the tranny right in the pocket of the hub/shaft of the mip. If that makes any sense lol http://www.hot-racing.com/index.cgi?...=SCP1505;c=420 Be aware this is locked, so beef up elsewhere as needed... Last edited by Meatwad; 01-05-2014 at 02:21 PM. |
01-05-2014, 02:20 PM | #5 |
| Re: 32p Gear matches? I wonder what is different about your 60t/mip combo than mine. A 60t still fits under the cover with minimal sanding in one spot.
01-05-2014, 02:21 PM | #6 |
| Re: 32p Gear matches? |
01-05-2014, 02:22 PM | #7 |
Ah good that it works.. Haven't tried an axial slipper.
01-05-2014, 04:17 PM | #8 |
Rock Stacker Join Date: Jan 2007 Location: Carson City
The Kimbrough 32p 60t spur gear will fit with a little sanding just like Calderwood said. I wish I would have known that when I threw my 60t spur gear on. I did find out the Kimbrough spur gear is tougher than the Axial spur gear cover, it self clearanced itself, had to clean a little black out of it. The Duratrax 32p 56t spur gear I got needed to have the main large hole slight dremeld to fit right, it's what I'm running now with no problems. |
01-05-2014, 05:18 PM | #9 |
01-05-2014, 07:28 PM | #10 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
I am trying something now that I don't believe I have seen before on my dmg koh#7 rebuild. Get a super shafty beefy top shaft and a traxxas summit or revo slipper set their is all kinds of 32p gears mid 30's-over 50's reason I am trying this. I already have a vp fully built bomb proof transmission. You cant change the pinion gear teeth the 3rd gen rrp spur used is 56t. I wanted more options. Pluse if u are running all metal everything a plastic spur would be a cheap breaking point if anything were to break. Sent from my SGH-T889 using Tapatalk |
01-05-2014, 11:09 PM | #11 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
I run Duratrax and Kimbrough. Both good, but I find the Duratrax a little more true. It is definitely a tight fit in the center, but never had to dremel one.
05-30-2014, 06:44 PM | #12 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Duratrax are great!! I just installed a 32P 56T spur on my Wraith. It needed a little dremel help because it was too tight. I used the cone style stone thingy....not sure what it is called in the dremel. Once I used it the spur gear fit super tight and the 3 holes lined up perfectly to the holes on the spur. I was going to try a 60T but figured 56/14 was my best option for the Tekin Pro 4 3300kv with MMP. Would 60/14 be ok? Just checking because I do have the 60T spur here too. |
05-30-2014, 07:00 PM | #13 |
Rock Stacker Join Date: Apr 2014 Location: canada
I used a traxxas 54t 32p off I think a slash or a slash or 4x4 slash with I believe an 11 tooth pinion.As close to 5:1 as I can get
05-31-2014, 07:49 AM | #14 |
Pebble Pounder Join Date: Jul 2013 Location: SoCal
I have a Kimborough 60t spur, stock wraith slipper and no clearance issues with mip's. With a 14t pinion the mesh is just a tad tight with the stock motor plate.
32p Gear matches? - Similar Threads | ||||
Switching to 32p gear help | throttlejock27 | Axial Wraith | 23 | 03-26-2013 09:22 PM |
How to Reduce 32P Gear Noise | 5.2LJeep | Axial Wraith | 12 | 01-17-2012 11:36 AM |
48p to 32p gear conversion | Pappy | General Scale Talk | 5 | 05-16-2011 12:18 PM |
