01-06-2014, 10:53 AM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
| Clocking the axles
I see that the chubs and lockouts can be moved a little bit either way from stock. Is there any benefit from moving the pinion angle up?
01-06-2014, 12:10 PM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Clocking the axles
Moving the chubs or lockouts will not change the pinion angle, only the caster in the front. Pinion angle requires different length upper or lower links.
01-06-2014, 01:17 PM | #3 |
Pebble Pounder Join Date: Jan 2012 Location: colorado springs
And by clocking your chubs you can move your steering linkage up away from obstacles which can help you from getting stuck in some cases sent from my 5th scale |
Clocking the axles - Similar Threads | ||||
Clocking Axles | HoupS | Redcat Crawlers | 10 | 01-11-2012 06:30 AM |
Clocking Clod axles? | ToTheMAXXcrawler | Tamiya Clod Buster | 4 | 06-26-2010 10:36 PM |
Whats Clocking your axles??? | cmacclel | XTM Crawler | 3 | 08-16-2009 04:16 PM |
clocking axles | legion1capone | Newbie General | 1 | 03-24-2009 02:33 PM |
Clocking the axles. | hakmazter | Newbie General | 2 | 10-08-2008 02:11 AM |
