01-23-2014, 02:23 AM | #1 |
Quarry Creeper Join Date: Dec 2013 Location: ][V][
| help with beef tube install!!
hi all. ive searched this as much as I can. but I cant figure it out. I bought a set of beef tubes from biggins69 and I thought it was just slip it on and screw it back down. but my axles (rtr wraith poison spyder axles) wont clear the tube. does anyone have any install pictures? thanks in advance
01-23-2014, 03:12 AM | #2 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Re: help with beef tube install!!
It is a very,very snug fit. Use some lube to slide the tubes in. First you need to remove the shock mount screws & axle truss screws. Watch the notches in the beef tubes as your screws need to slip thru,if your not lined up,remove the diff cover push the tube back out and try again. Good luck they are fairly easy install.
01-23-2014, 07:38 AM | #3 |
Rock Crawler Join Date: Nov 2004 Location: roanoke
I have the metal ones, put them in a drill and used sandpaper to get them small enough to press in.
01-23-2014, 10:29 AM | #4 |
I think I have a defective tube? I can't get the tubes to clear the axle shafts from either side. I have no fitment issues with the axle housing. just can't get the axle shafts through the beef tube due to that "stepped lip" on both sides Last edited by wsmb; 01-23-2014 at 10:32 AM. |
01-23-2014, 01:29 PM | #5 |
If it's for the rear, that flange needs to be shaved down a bit on the axle shaft. I've seen it mentioned as a requirement somewhere.
01-23-2014, 03:55 PM | #6 |
thank you sir. what can I use to file it down?
01-23-2014, 05:21 PM | #7 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
| Re: help with beef tube install!! ....a file. or a Dremel, bench grinder, angle grinder, die grinder, lathe, belt sander, orbital sander, or if you dont have any of those tools you probably could just rub the flange on an rough rock and grind off enough of the flange to get them in. . |
01-23-2014, 05:47 PM | #8 |
Well.. yeah I chucked up the axle shaft into my hand drill and used a dremel in the opposite direction. |
01-23-2014, 06:53 PM | #9 |
thanks for the help guys!
help with beef tube install!! - Similar Threads | ||||
Beef in Yer Rear! to Tube? or NOT to Tube? | Big Tex | General Scale Talk | 29 | 01-08-2014 03:56 PM |
beef tubes install,some Q&A before I start | realsickclown | Axial Wraith | 14 | 07-25-2013 07:52 PM |
Beef tube ? | jcsaxial | General Crawlers | 3 | 08-28-2012 02:15 PM |
*REVISED* gunnar beef toob install | KC_JoNeS | Axial AX-10 Scorpion | 71 | 07-31-2011 03:51 PM |
Gunnar's axle beef insert-fab and install | gunnar | Axial AX-10 Scorpion | 95 | 10-12-2010 09:17 AM |
