02-18-2014, 06:40 PM | #1 |
Newbie Join Date: Mar 2008 Location: Mt Juliet,TN
| Wraith foam
Is it better to run foam or no foam in the tires of a wraith?
02-18-2014, 07:10 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: Duluth, MN
| Re: Wraith foam
Foam is definitely important in 99% of applications unless you have one of the gmade air ride systems. There are different foams types and firmness'. Go with something you think you may like and base your assessments off of that, kind of a crappy way but one of the few/only unless you have friend or shop local who will let you borrow/try some.
02-18-2014, 07:21 PM | #3 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
| http://www.rccrawler.com/forum/membe...-ark-12852.htm Maybe shoot CI a PM and tell him what ya got and what ya plan to run and he will prob help you get the right foam set up. I own several sets of CI foams and have not been disappointed yet. |
02-18-2014, 08:37 PM | #4 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: Wraith foam
I 2nd C.I. they can't be beat
02-18-2014, 10:28 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
| Re: Wraith foam
I am running panther firm crawler memory foams and I like them a lot. A 2 stage would be better but for a cheap foam on a decently fast rig they do well. Ymmv.
02-18-2014, 11:29 PM | #6 |
| Re: Wraith foam
Probly want to consider some dual stage foams if in the 8lb plus weight range. If under 8 lbs there's are lots of memory foams that will work well in ripsaws even dual stage with memory outers |
02-19-2014, 02:20 AM | #7 |
Pebble Pounder Join Date: Jan 2011 Location: london,England
| Re: Wraith foam
I run these they are great Single Stage Closed Cell for 2.2 Tall Tires |
Wraith foam - Similar Threads | ||||
Wraith Foam Tuning - Setups and Tips | Harley | Axial Wraith | 23 | 08-14-2014 07:47 AM |
Setup of stock Wraith wheels tires and foam | 2Crawl | Axial Wraith | 10 | 10-31-2013 08:36 AM |
Wraith stock tires inlclude foam? | Madkiki | Newbie General | 2 | 09-01-2012 05:12 PM |
Wraith 2.2" R35 Ripsaw Foam Shaving? | Big Tex | Axial Wraith | 13 | 06-28-2012 05:13 PM |
TSL foam set up on wraith | highhpcummins | Tires and Wheels | 3 | 11-03-2011 10:53 AM |
