02-24-2014, 12:29 AM | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Axle gone bad?
im not sure quite wtf is happening on this one and im kinda stumped??? I serviced my kids wraith tonight to find after installing the stock gearset in the rear axle, to find it binds the crown/pinion ONLY when i slap in the x2 screws into the hub on the one side. Ive looked at the shafts themselves to see if these were warped or bent but they look in great shape. The axle is not damaged other then typical scuffs from driving the rig. Bearings are in mint shape.... Even the crown and pinion are not damaged? for some unknown reason its only when i attempt to install these last two screws into the left hub?? any ideas where this is going?? thanks in advance! Last edited by SwampDawg; 02-24-2014 at 12:38 AM. |
02-24-2014, 12:56 AM | #2 |
| Re: Axle gone bad?
is the parts in question the stock plastic chubs and axle housing? it could be the screws are going in too far now due to wear or compression of the plastic that is allowing the screws to contact the axle shaft--BTDT
02-24-2014, 05:43 AM | #3 |
| Re: Axle gone bad?
no, unfortunetly its not this easy :P
02-24-2014, 09:04 AM | #4 |
Double check that the inside pinion bearing is seating completely and there's no gunk preventing it. Occasionally stuff gets between those two bearings.
02-24-2014, 10:12 AM | #5 |
| Re: Axle gone bad?
okay...will do! ill have a look. |
02-24-2014, 11:13 AM | #6 |
| Re: Axle gone bad?
ok!!! figured this mystery out! i installed a new crown and pinion....FAIL! Started looking at everything again to find out that the one hub was not resting completely on the axle. (not going far enough and still visually could see the grooves). Pulled the short driveshaft out and grinded off the ridge where it rested on the differential. FIX!! this ridge was pressing the differential hard onto the pinion and causing my dilemna. |
02-24-2014, 11:52 AM | #7 |
| Re: Axle gone bad?
This is what is referred to as the short axle shaft issue. There is a whole thread on it. The early Wraiths had a short shaft that was out of spec.
02-24-2014, 12:06 PM | #8 |
| Re: Axle gone bad?
i remember hearing of this issue but it never crossed my mind until you mentioned it. ill have to grab a new short shaft another time, but for now this will have to do. Its on a stock setup for now anyhow so if it fails ill replace whatever blows up in my face. lol thanks for the replies! |
Axle gone bad? - Similar Threads | ||||
signs of a bad pack?? or just a bad motor. | Docwolf | Electronics | 5 | 04-15-2013 06:05 PM |
bad batteries or bad esc? | bigred22 | Axial Wraith | 5 | 11-29-2012 08:11 PM |
Bad Rear Axle!!! | 1/18th_Nylint_Auzzy | General Crawlers | 5 | 09-11-2006 05:21 AM |
No Traction to Rear End... poss bad drive pin in axle | Wheels4186 | General Crawlers | 6 | 01-01-2006 07:02 PM |
